Konica Minolta Bizhub C284 Service mode
  • Alex1
    • Oct 2012
    • 285
    I have a Konica Minolta Bizhub C284 which I can bring up service mode but can not access service mode I've tried 9272 9272 9272 9272. I tried it as above i tried it as 9272 9272 only. Ive tried all codes. The code has been changed. I was then told to do a firmware update that it will bring the service mode code back to default, tried that with no success. Any help will be appreciated.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Re: Konica Minolta Bizhub C284 Service mode
    Have you tried 12345678, or 00000000
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      *Not sure why this posted twice
      • Alex1
        • Oct 2012
        • 285
        Hi, Yes I did try those codes. No luck
        • Woxner
          • Jul 2011
          • 851
          there is a reset firmware tool you could use. it is use to reset a board that is not been cleaned and you need to use that pwb
