Scan to USB memory using Sandisk FD
  • aleksander
    • 378
    #16
    Re: Scan to USB memory using Sandisk FD
    Originally posted by Synthohol
    the solution is to use a drive <4g that is proven to work.
    even scan to USB has drives that dont play well.
    Reference
    Following are the USB drives tested and approved for the scan to USB function:
    Model Maker Result
    RUF-C64M/U2 (64MB) BUFFALO Passed
    RUF2-E128-B (128MB) Passed
    RUF2-S1G+C4-BK (1GB) Passed
    MF-UU2512WH (512MB) ELECOM Passed
    MF-AU201GGT (1GB) Failed
    GH-UFD2GTB (2GB) GREEN HOUSE Passed
    TB-M2/1GG (1GB) I-O DATA Passed
    TB-B2G (2GB) Failed
    TG256-NRX044 (256MB) Passed
    SDCZ6-1024-J65 (1GB) SanDisk Passed
    USM512JX (512MB) SONY Passed
    USM1GJ (1GB) Passed
    Note: Only USB sticks formatted with FAT32 are supported as product specification. The above list was verified with FAT32 USB memory sticks.
    CAUTION: If the USB drive has the U3 security option, remove this feature from the USB before trying to scan because this feature disables the scanning of files stored on the USB stick.
    the attached PDF has more info than the picture.
    thank you
    • Don N.
      • Nov 2011
      • 409
      #17
      some drives have a hidden partition and dont play well with copiers.
      there is a list of certified compatible USB drives to be used in KM machines. the rest are hit or miss.
      also the config of the ram chips on the flash may not be compatible. some are double density and others may have other characteristics that prove incompatible.
      just because it may scan to it does not guarantee it will load firmware from it. or vice versa.
      YES!
      We got a pack of promotional 4GB drives off Amazon, mainly for putting drivers on & giving to customers. They work fine but not for loading FW.
      Another order worked fine for FW. Hit-n-miss.
        • 22996
        #18
        I hardly believe that this thread has dragged out this far.
        Find a drive that works and use it. It is entirely unnecessary to test all the drives that won't work first.
