Scan to USB memory using Sandisk FD
  • aleksander
    • 378
    Hi all,
    I have problem with Scan to USB memory. I use bizhub 423 series and Sandisk USB memory 8GB & 16 GB. I do scan to USB memory with Compact PDF format and its all failed. No problem when using Kingston & HP USB memory. Anyone can give me solution for this problem.
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: Scan to USB memory using Sandisk FD
    423 series works best with 4 gig or smaller regardless of brand.
      • 23008
      I agree. Keep in mind that the device, bizhub 423 was designed when a 2GB USB was the largest size available. Use any smaller drive.
      When I'm using USB sticks with copiers I rarely use larger than 2GB. Typically I try to use the smallest drive capable of holding the data. =^..^=
      • copier tech
        • 8144
        Originally posted by aleksander
        Hi all,
        Might be worth a firmware upgrade this may allow you to use larger drives.
        • rrrohan
          • Sep 2011
          • 1977
          Do they even make firmware for these anymore
          Sent from my SM-G955F using Tapatalk
          • copier tech
            • 8144
            Last version release was A1UD0Y0-F000-GC4-C4.exe
            • dave w
              • Jun 2015
              • 230
              Agree
              The only merit of being a horder is i've never thrown away old usb stick and now they come in handy.
              • aleksander
                • 378
                But there is no problem when I use 16 GB Kingston USB memory. Scan to USB works well.
                Whats wrong with sandisk?
                • Synthohol
                  • 5824
                  some drives have a hidden partition and dont play well with copiers.
                  there is a list of certified compatible USB drives to be used in KM machines. the rest are hit or miss.
                  also the config of the ram chips on the flash may not be compatible. some are double density and others may have other characteristics that prove incompatible.
                  just because it may scan to it does not guarantee it will load firmware from it. or vice versa.
                  • aleksander
                    • 378
                    Where should I get this info?
                      i ALWAYS format a new USB like Blackcat said there cold be a hidden partition on it or the 'scan disk' utilities on it could be stopping progress... always use Fat32
                      • aleksander
                        • 378
                        Of course I always format a new USB with fat32 format. I've already check for possibility there is a hidden partition, and there is no hidden partition. And the point is : this problem only happened with Sandisk USB memory. And there is no problem when using Kingston, HP etc
                        • tsbservice
                          Field tech
                          • 8016
                          @aleksander, what exactly you did not understand from the post above? There's no guarantee that some devices will work and some don't. List of compatible drives for this machine will be atleast obsolete and will not include your drives.
                          • aleksander
                            • 378
                            So, there is no solution?
                            • Synthohol
                              • 5824
                              the solution is to use a drive <4g that is proven to work.
                              even scan to USB has drives that dont play well.
                              Reference
                              Following are the USB drives tested and approved for the scan to USB function:
                              Model Maker Result
                              RUF-C64M/U2 (64MB) BUFFALO Passed
                              RUF2-E128-B (128MB) Passed
                              RUF2-S1G+C4-BK (1GB) Passed
                              MF-UU2512WH (512MB) ELECOM Passed
                              MF-AU201GGT (1GB) Failed
                              GH-UFD2GTB (2GB) GREEN HOUSE Passed
                              TB-M2/1GG (1GB) I-O DATA Passed
                              TB-B2G (2GB) Failed
                              TG256-NRX044 (256MB) Passed
                              SDCZ6-1024-J65 (1GB) SanDisk Passed
                              USM512JX (512MB) SONY Passed
                              USM1GJ (1GB) Passed
                              Note: Only USB sticks formatted with FAT32 are supported as product specification. The above list was verified with FAT32 USB memory sticks.
                              CAUTION: If the USB drive has the U3 security option, remove this feature from the USB before trying to scan because this feature disables the scanning of files stored on the USB stick.
                              the attached PDF has more info than the picture.
