C554e
  • Majava
    • Jul 2018
    • 6
    [CQ] C554e
    Hi
    I have a C554e that keeps detoning black coming up with C2557. Changed k tank and HV. The gradiation patten (copy) is fine , the print one is not good on the half side of the A3. When i tone the machine up it runs for a day or so then C2557 by that time tcr level is on 0%.
    Please anyone with a solution.
    Jabu
  • Toxic
    • 697
    Re: C554e
    You could do some search,forum is full of solutions like this.
    Are you tech or end user?
    http://www.copytechnet.com/forums/ko...23=#post483645
    • Majava
      • Jul 2018
      • 6
      Re: C554e
      Do you think a end user can change a tanks and hv??
      Thanks for the advise
      • Toxic
        • 697
        Re: C554e
        You may not be aware of what they are capable of doing to some end users.
        At least what i saw on the field.
          • 23008
          Re: C554e
          Do they do very high image fill ... say, over 70% of any single color? Continuous printing of high fill originals can deplete the developer density below 2% without ever showing a toner add indication. It can go directly into a C2557 or "An internal error has occurred."
          AFAIK, this situation is just a limitation of the e series. If you bump up the developer density to 9% you can delay it, but fill levels over 70% of any one color printed continuously will detone the developer. =^..^=
