Konica Minolta 454e
  • antone
    • Oct 2014
    • 344
    Konica Minolta 454e
    Using coin op hook up...can the USB......option be disable! How can this to work with out free copies
    Sent from my SM-N950U using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: Konica Minolta 454e
    Coin OP does not use usb. It uses a connector on the prcb board left side.
    If your vending unit only has usb it's likely not for a konica at all.
      • 23010
      I don't think that he wants to connect the coinop to the USB. I think he'd like to restrict use of the USB port to stop free copying from USB.
      And you can disable printing and/or scanning from USB, but you may have difficulty figuring a way to make the coinop to charge for those functions. =^..^=
      • Synthohol
        • 5892
        If vendor mode is on you still can't print from usb.
        I guess I'm not understanding the problem.
        The front usb plugs into the mfp board outside the machine.
        Just unplug it and tuck it behind a cover!!!
        Very easy to solve if you just stop and think.
        You can also disable everything from usb in admin mode and still be able to load movie data or drivers in service mode.
        Antone, if you need a manual become a contributor here and I'll link you to my server.
        • mincopier
          • Dec 2015
          • 289
          Go into Administrator mode, User Box Settings and you can turn the USB ports of completely here. Scanning is off by default. If worried people will find out how to get in and revers it just change the Admin password.
