Getting black lines - Konica Minolta C224e
  • musthafavi
    • Aug 2017
    • 76
    [Misc] Getting black lines - Konica Minolta C224e
    while printing/Copying Getting black lines in print out
    Machine: Konica Minolta C224e
    please find the attached for your reference
  • Max
    • Oct 2011
    • 561
    Re: Getting black lines - Konica Minolta C224e
    Charge/Grid in toner
    • copyman
      Owner / Technician
      • Sep 2005
      • 4730
      What are the consumable life counts? Did you pull the K developer unit and see if it dumped? Lines are usually from black drum, transfer belt or fuser. In this case I would think black drum needs to be replaced
      • musthafavi
        • Aug 2017
        • 76
        could you please explain
        • musthafavi
          • Aug 2017
          • 76
          Thank you, I will try with the new drum unit
          • copyman
            Owner / Technician
            • Sep 2005
            • 4730
            In the meantime you could probably change the direction of the paper to feed long ways and it will most likely miss the lines on edge.
            • techie0419
              • Apr 2017
              • 36
              When I looked at the image, my first thought was the black drum as well. It's hard to tell for certain whether it is a black line where the page should be white, or a blank are where there should be text...if blank/void, then the area is not charging properly. Either way, the drum would be the easiest place to start. And copyman's idea of turning the paper 90 degrees in the tray is good, particularly if you have to wait on the drum to arrive.
                • 23009
                I had one recently like this with an address label stuck to the transfer belt. =^..^=
                  you are not a tech are you?
                    thank you, i will try with the new drum unit
                    did you check the dev units?
                      • 14852
                      I think he was just asking what "Charge/Grid in toner" means. I'm a tech and I don't know what that means.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4730
                        If you want to be sure. swap the life chip from black with one of the color drums. if the lines come out the color you swapped with and no black lines then you can get yourself a black drum.
                        Only way it would make sense to swap drums is if you have old style drums with small screw for chips. New style chips are riveted so people can't buy less expensive black drums and swap the chips for color, drums are identical except chip. I'm not saying the rivet stops some people. I would never do something like that
                        • JDR
                          • Jan 2015
                          • 82
                          Just disassemble your black drum and clean the grid + corona.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4730
                            Keep in mind you can clean the grid, charge, etc but if it is over life it can cause "any" of the developer units to pull developer. And if a color dev unit gets ruined you are looking at $400+ each to replace. Genuine black drums cost less than $100 so why even take the chance!
