C-4101 bizhub C220
  • aleksander
    • 378
    C-4101 bizhub C220
    Any have experience with C-4101 ini bizhub C220?
    I've already replace PH unit & PRCB but still have the same error.
    Any solution ?
    Sent from my Lenovo K53a48 using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: C-4101 bizhub C220
    Did you change the PH relay board as outlined in the manual?
    A0EDH00200
    • aleksander
      • 378
      A0EDH00200
      Yes and C4101 still occurred
      • Synthohol
        • 5847
        in service mode are you able to run load check?
        • Albonline
          • Sep 2008
          • 1151
          fyi the c220 ph is not the same as c360 or c280
          • aleksander
            • 378
            Solved. Harness & connector problem.
