Konica Minolta Buzhub 751 Toner Supply Motor
  • Naveed Shahid
    • May 2008
    • 162
    [Misc] Konica Minolta Buzhub 751 Toner Supply Motor
    Hello Every One
    I am Facing Problem Toner Supplying Motor Not Working I Changed Drum Developer Cleaning Blade After 5 Thousand Copies Its Get Stop I changed Toner Control Sensor Under The Drum , I Changed Toner Hoper Unit But Still Facing Problem Toner Supply Motor Not Working Copy Qua;ity Getting Light
    Plz Advice me
  • korthr5
    • Feb 2016
    • 39
    Re: Konica Minolta Buzhub 751 Toner Supply Motor
    hello
    I have the exact same problem, and i cant find the solution.
    • Albonline
      • Sep 2008
      • 1098
      Originally posted by korthr5
      hello
      compare soft switch list with working unit , a non documented bit has been set. i have seen this before.
