Bizhub C550 color problem
  • rindraintsoa
    • Sep 2010
    • 55
    Dear All,
    I have a problem with my C550 machine, as you can see in the sample page the machine print too much green, I have already changed imaging unit, transfert belt, laser unit but no change, does anybody send any suggestion. Thank you very much in advance.page1.jpg
  • Woxner
    • Jul 2011
    • 852
    Re: Bizhub C550 color problem
    have youi done the inialize and reset the gradation.
    • rindraintsoa
      • Sep 2010
      • 55
      Yes, I have changed everything without any good result (transfert belt, laser unit, HV1, HV2, etc). The problem still persist, does anybody have a suggestion?
      • Schneider
        • Sep 2018
        • 25
        Its very odd - tried a main board?
          you have too much CYAN ..not green. Y & C = G.
          look at the dispensing ratios
          • mo0651
            • 1054
            I think Phil is on it. What have you done with the Imaging units???
              gradation adjust is not PARTS but a service mode function. replacing parts should be done AFTER calibrations/adjustments have failed.
                • 23010
                So you're not even going to look at the consumables, like imaging units? In addition to cyan massively overtoning, magenta is massively undertoning. You must have been talking to the hotline: "Oh yeah, it's got to be a board..."
                • rindraintsoa
                  • Sep 2010
                  • 55
                  Hi all,
                  I would like to mention that I am a field engineer so the first thing I have done was to change the IU. When I say green I understand that Green is mix of Cyan and Yellow. So any feedback would be much appreciated. Thanks all
                  • Zesti
                    • Jun 2009
                    • 308
                    Can you share level history1 and Table No. data.
                    Can you tell briefly describe history of what happened?
