Bizhub 454e Error C-E004
  • Zesti
    • Jun 2009
    • 308
    Hi guys,
    This machine came to me, a along and agonizing history attached with the machine, somebody was talking about a mouse some posts back.
    Anyways. The machine got ready, if go into service mode it gives away E004, say after about 3 mins or so, if stay on copy screen it gives message "An internal error occurred and will be restart"....
    Any thoughts about that....
  • copyman
    Owner / Technician
    • Sep 2005
    • 4681
    Re: Bizhub 454e Error C-E004
    I found this same issue on this forum, here is one example. There is probably more if you do a search.
    C284e error c-e004
    • Zesti
      • Jun 2009
      • 308
      Hi guys,
      Got that E004 issue, solved it...
      FYI
      The machine give away E004 after about 2 mins.
      Noticed that the machine kept saying Preparing Scan/Box after some while it gives away code and in the admin settings NEtwork never shoed up and I was curious about that.
      I formatted HDD to no avail.
      Then did an NVRAM reset and reloaded FW.
      Tadaa machine is working now without error.
      But one thing noticed later, its not entering service setup..utility-counter-keypad S00S01 but nothing happens...
      any suggestions or I have to dig in again...
      • Zesti
        • Jun 2009
        • 308
        Ok, the machine entered into service mode, s00s01, what I noted is that that the panel and touch screen respond a bit slow than normal..
        Any thoughts..
          • 23007
          I'd change the HDD. =^..^=
          • Zesti
            • Jun 2009
            • 308
            Yes I'll check the machine for couple of days....
