Bizhub c360 - Subtle black stripes
  • patefilo
    • Jun 2016
    • 13
    Hello,
    Whenever I print heavy paper, I obtain black stripes all along the sheet. I tried to take a picture of them and it was quiet challenging:
    On regular paper, they don't appear...
    Also, the sheet, globally, turns slightly from white to "washed" white color during the process.
    I cleaned twice the Electrostatic Charger Wire and the Printheads, following the user manual instructions, but nothing changed.
    Would you have any advice for me? Thank you!
  • tsbservice
    Field tech
    • 7933
    Re: Bizhub c360 - Subtle black stripes
    Car wash will clean your car but when tyres are worn out cleaning them will not do any good. Same with your MFP. There is some consumables that needs to be replaced at certain life/copies, what about them?
    Hard to share atleast copier counter or what was changed/done...
      • 22965
      Did you, perchance, select Heavy media type so that it can fuse properly? =^..^=
