Bizhub 1052
  • copytechman
    • Nov 2008
    • 966
    Bizhub 1052
    Separate issue, i'll be looking through dip sw settings however does anyone know if theres a setting to turn on offsetting/shifting of jobs on a fs612 on a bizhub 1052? It won't offset either in copy or print no matter what.
    Thanks for any help!
    A!
  • jotunn
    • 635
    Re: Bizhub 1052
    Maybe it's not working as you wish, just because it is not a finisher for this machine?
      • 23010
      Re: Bizhub 1052
      Like he said, per the brochure, it's not a compatible accessory:
      The page may have been removed or deleted. Please check the regional website for details.
      • copytechman
        • Nov 2008
        • 966
        Re: Bizhub 1052
        Apparently you are correct it must be the fs532 (if I read that correctly) my error. Fs612 might be the finisher for the c3070L but I may not be correct there either.
        Regards!
        A.
          • 23010
          Re: Bizhub 1052
          Regards!
          A.
          Nope. The FS-612 mated to the bizhub C6000. =^..^=
          • copytechman
            • Nov 2008
            • 966
            Re: Bizhub 1052
            Well that's fine it's the 1052 I'm interested in regardless. As clueless as I apparently sound atm tho!
            A!
              • 23010
              Re: Bizhub 1052
              The offset mechanism is very reliable. I've had a few apart just because it was in the way of something else. I suggest that you do a little exploratory surgery.
              Take it apart ... observe. =^..^=
              • REGSIS
                • May 2016
                • 435
                Re: Bizhub 1052
                and C1060L
                • copytechman
                  • Nov 2008
                  • 966
                  Re: Bizhub 1052
                  Not necessary to explore further it's a setting in Admin settings that turns that feature on. Go figure!
                  Thx!
