C258 print error
    • 14972
    C258 print error
    Hey all
    I have a customer with a BH C258 and she is getting an error while printing. She says it is from a powerpoint presentation grid. (Not sure what that is)
    It will print some and then stop. When it stops it prints out the error indicated on the attachments.
    Any help is appreciated
  • copier tech
    • 8200
      • 14972
      Re: C258 print error
      The firmware is up to date, but I will be going in to re-install it. Just in case.
      Thanks for the response.
      • tsbservice
        Field tech
        • 8052
        What driver they use? Check and make sure they are using latest. If they print with PCL6 use PS instead and vice versa. Definitely looking like FW or driver(driver/software) issue.
        • jotunn
          • 635
          • Synthohol
            Certified Konica Expert
            • 5892
            the margins are off. select fit to page and it usually works.
            its a driver issue as the machine itself would not kick out a 2nd page if it only received one page.
            • Bix
              • Apr 2018
              • 1421
              Hello,
              maybe it's a character processing problem. Go to the Quality driver settings> Font settings> Download fonts to the printer: Image.
              Alternatively, you can save the file as a PDF to your client before printing.
                • 14972
                Originally posted by Bix
                Hello,
                Bingo!!!! She called yesterday and said when she saves doc as a PDF it works fine.
                Thanks everyone for the responses
                • guitar9199
                  • Sep 2016
                  • 1100
                  I was going to suggest switching to a PCL5 driver. I'm starting to see some quirky things happening with Windows and PCL6, to the point where I'm just not installing that driver anymore unless the customer SPECIFICALLY requests it.
