C754e b/w copies counting as color
  • Brett GS
    • Jun 2013
    • 154
    I got a Bizhub C754e that when set to auto color and when the client copies a black and white document off the glass it click a color click,there is no color at all on the document.
    From the ADF it click a black click.
    Any advice as too what setting i can try,i will be going there tomorow.
    Brett
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: C754e b/w copies counting as color
    just set the machine to do black and white by default when they what color they can choose color there is something where you could choose the auto color range where it switches to color instead of black and white it's like sensitivity black and white sensitivity or something like that
    • tsbservice
      Field tech
      • 8009
      You may check criterion level to discriminate between B&W and Color originals under:
      Utility(User settings) > System settings > Auto color level adjust
      • Brett GS
        • Jun 2013
        • 154
        Yip found it in the manual, ACS level
        Will give it a go tomorow.
        • Brett GS
          • Jun 2013
          • 154
          Thanks will check that too
            • 23007
            All it takes is a little discoloration of the original, or a colored mark on the slit glass to trigger auto color. Better to default to B&W, and let color users make a selection. And yes there is a sensitivity adjustment in Utility. =^..^=
            • tsbservice
              Field tech
              • 8009
              Yep, think BC nailed it. I forgot that original glass has to be clean of any kind of contamination like ball-pen, etc. Make sense, as DF scans through slit glass(first side). Clean entirely original glass and do test, before trying to adjust anything.
              • Zesti
                • Jun 2009
                • 308
                Buddy, you are a genius- cos genius some time miss very obvious thing....thnaks God u didn't go for a FW upgrade or NVRAM reset.
                • Brett GS
                  • Jun 2013
                  • 154
                  Turned out being the ACS setting under user setting, set it to 2 and issue sorted.
                  Thanks for all the input.
