Airprint/Mopria
  • NeoMatrix
    Senior Tech.
    • 3513
    #16
    Re: Airprint/Mopria
    Some AIRprint MFD's drivers configure/install themselves on a total different subnet to the existing LAN or WiFi network.
    If the above is not the fault try :
    Check your modem/router is not set for individual WiFi network login.
    Some routers can be set for similar WiFi guest mode to isolated every other login from seeing each other including the LAN.
    Ie. If ten WiFi users login at the same time; none of those logged onto the network can see each other, including the LAN network printers.
    Solution.
    Enter the router WIM and change the router setting.
    FYI.
    WPA2-PSK WiFi protocol has a vulnerability hack. I believe there is a next Gen WPA3-PSK available.
    HTH
    • Synthohol
      Certified Konica Expert
      • 5922
      #17
      Re: Airprint/Mopria
      just had an airprint call with 2 diff subnets.
      the IT guy enabled mDNS, entered the copier subnet and Voila!
      popped up on the phone in like 10 seconds.
      BTW, no extra accessories needed, worked out of the box.
      • mincopier
        • Dec 2015
        • 289
        #18
        Re: Airprint/Mopria
        As mentioned previously no extra accessories are needed for AirPrint/Mopria to work on a Konicaminolta "8" series machine.
        It does need to be enabled in Administrator Settings, Network. Maybe Detailed Settings after Network.
        If the copier is wired the local wireless must have access to the wired network. The devices must be on the same network as the copier.
