Password after replace Drum on Bizhub 283
  • kazihaha
    • 100
    [Misc] Password after replace Drum on Bizhub 283
    I just doing with Konica, the bizhub 283 need password after replaced Drum Unit, I already try 92729272, 00000000, 12345678 but nothing work, the old suplier ask me bring the board to flash the firmware ... 50$ (
    Could someone help me?
    There the tool NVRam resetting?
    My email: kazihaha@yahoo.com
    Thanks so much.
    https://sieuthithietbivanphong.com
    Re: Password after replace Drum on Bizhub 283
    Originally posted by kazihaha
    I just doing with Toshiba, the bizhub 283 need password after replaced Drum Unit, I already try 92729272, 00000000, 12345678 but nothing work, the old suplier ask me bring the board to flash the firmware ... 50$ (
    Thanks so much.
    RTFM
    or GTFM
    • kazihaha
      • 100
      RTFM
      or GTFM
      Sorry what's that? I'm new to Konica
      • tsbservice
        Field tech
        • 8081
        First get at least Service Manual, read it, then ask Questions.
        Means that original password was changed and with OR without Manual you has to ask those who sell you machine for it.
        There is a chance if you donate here somebody send you Firmware.
        • Synthohol
          Certified Konica Expert
          • 5922
          the drum unit automatically rests the counter and you can do the gradations through admin mode.
            • 15069
            Counters have to be reset manually on the BH283. Also so have to run TCR adjustment in service mode. Without service password these steps can't be done.
              RTFM = Read The F'ing Manual
              GTFM = Get The F'ing Manual
              • Synthohol
                • 5922
                Aw man, sorry about the bad info, I've worked on so many 4 5 7 8 and 9 series I totally forgot the legacy machines.
                Also I hope the developer was changes too or you will likely get 255x codes. Both drum and dv are replaced as a set.
                  • 23010
                  You have to 1) get the CE password or 2) reset the CE password:
                  1) contact the genius who changed it.
                  2) place a hotline call, and provide the 20 digit reset code. KM then provides you with a 20 digit code to enter, to reset the CE password to it's default.
                  Those are your only two choices. =^..^=
                  • kazihaha
                    • 100
                    The one who change the password is technician of Master Dealer here, they do not want their customer have other supplier.
                    How much does it cost for Password crack? If I donate 10$, is it OK?
                    • rrrohan
                      • Sep 2011
                      • 1977
                      You can glitch past the CE password screen. I haven't done it in 4 years so might of been patched
