Konica Minolta C253 (Develop Ineo+ 253) - HDD Error - Enter Service Mode during Error
    • 14973
    #16
    Re: Konica Minolta C253 (Develop Ineo+ 253) - HDD Error - Enter Service Mode during E
    Originally posted by DrogenDiego
    I've had the machine running for an hours with no change in the error code.....
    IT's the screen of death I can't do anything...
    So, even after an hour with the code showing when you press the utility/counter button there is no response?
    If that is the case there is something else going on.
    Have you tried loading firmware?
    • DrogenDiego
      • May 2018
      • 11
      #17
      Hey maybe something else is wrong...
      No I haven't tried loading a firmware. As far as I known, the firmware is only available to technicians. So I have no means of getting a firmware.
      • CopierNerd
        • Feb 2015
        • 207
        #18
        Try reconnecting the HDD cable to the board and then check if it works. I wish i could have firmware for you.
        • albenbalinong
          • Sep 2015
          • 30
          #19
          Try to re install the firmware .. Then go to the service mode to uninstall hdd..
          • lazymangr
            • Feb 2017
            • 115
            #20
            when error comes up afaik you can press utility/counter to enter the menu to go to service mode all the time. you dont dismiss the error but it gets you to the counter so you can enter the service mode
            • DrogenDiego
              • May 2018
              • 11
              #21
              I disconnected the cable from the board. Same error. D004
              Then I reconnected everything and it gives me the wrong format error again.
              Pressing the utlity button doesn't do anything
              I am a little lost with this problem. We will probably get a new one since we rely on a copier and our company needs it....
              • Zesti
                • Jun 2009
                • 311
                #22
                I believe ur FW is corrupted and so is the HDD. Have u got FW?
                • DrogenDiego
                  • May 2018
                  • 11
                  #23
                  No I don't have a FW.
                  Well then this printer goes to the dump... too bad.
                  Or I gift it to someone who can fix it.
