Transfer Roller damaged, damaging Drum Unit
  • CopierNerd
    • Feb 2015
    • 207
    #31
    Re: Transfer Roller damaged, damaging Drum Unit
    Originally posted by allan
    Had one where the transfer roller metal guide was bent recently did exactly the same as you pictures.
    Not buying the mag brush theory on this one. look at the nature of the damaged. Mag brush will polish the surface off.
    The metal guide is OK.Not bent nor deformed.
    • CopierNerd
      • Feb 2015
      • 207
      #32
      Originally posted by Woxner
      if you line up the transfer roller and the drum you will see what the wear is. remove the two screws on each end of the transfer roller and remove all but one on each side (black spacer) i have replaced new dev and still did it within 100k. its too much pressure on the drum. dev unit can and will do more damage when they get too bad on the dev unit
      Thank you very much Sir Wayne for your kind reply.
      I have checked it. Transfer roller is exactly in line or opposite to the damaged area, which means the transfer roller end damaged the drum surface.
      Removing the black spacers adjacent to end is a good idea. I can try this before replacement.
      And if Dev Unit is damaging drum then how can we overcome or troubleshoot it?
      • CopierNerd
        • Feb 2015
        • 207
        #33
        I do not know what happened but every time i try to post or reply it takes me out. SIGN OUT!
        i cannot thank and like a reply. i do not have privileges. i am restricted.seems like the admin did this.
        i have violated CTN rules & policies, and i have apologized for that earlier.
          • 14927
          #34
          The drum made it passed yield, that is a good thing. Replace the drum, and the transfer roller if you think it needs to be replaced and pat yourself on the back for a job well done.
          • Muso
            • Oct 2022
            • 13
            #35
            Hi! Can someone please share the final solution for this issue? As I have 3 Copying Machine of this type and causing this issue. Thanks in advance.
            • subaro
              • Oct 2010
              • 1274
              #36
              From what I read and saw throughout this tread, it can only be the drum itself causing this issue. I think, there is some build up on the drum cleaning blade or a piece of hard toner rubbing against the drum inside the drum toner cleaning area. The dev unit I don't think would cause the drum to be worn like that. If anything, the dev unit mag roller itself would be worn and its usually the culprit of hardened toner somewhere in the dev area touching the sleeve.
              If the dev unit spacer was wearing on one side, then you might have seen a progressive fade, but it is in one spot that seems to indicate an object rubbing on the drum .
              Plus, the poster thinks that every consumable last its full life time, and that's not the case all the time. Some fail early, some go more than the rated life, its just that way.
              Disassemble the drum and look at the cleaning mechanism there. sometime there are stuff like paper and other things , that causes issues.
              • Muso
                • Oct 2022
                • 13
                #37
                Thanks a lot for your reply. I have checked the Drum several times and there is nothing starnge inside it. It even start making problem (Scratch ) with new drum unit with 1K printing. The Dev unit, drum and transfer roller is changed. Transfer roller is exactly in line or opposite to the damaged area, which means the transfer roller end damaged the drum surface.Removing the black spacers adjacent to end is a good idea. Highlited with red I found in prevoius post. But I can't find black spacers in transfer roller unit. Can anyone tell me is any black spacer in transfer roller? The picture is attached. Thanks.
                • subaro
                  • Oct 2010
                  • 1274
                  #38
                  This thread is interesting as to the various replies to the solution, the theories and fixes . To the theory of the mag roller brush causing this problem is supposed to be ruled out, as the brush is just toner and the carrier which are the iron oxide particles remains inside the dev unit, if it is a two component dev system.
                  Why it is happening as when new drum and dev and transfer roller is replaced, could be the door itself has some hinge strain and causing to put excessive force on the transfer section and some plastic part is rubbing against the drum. With the strain on the door, it may be out of alignment slightly and causing something to rub against the drum. just a thought.
                  The line is too obvious straight and the width is consistent, so it has to be something rubbing against the drum . The transfer roller sponge itself cannot damage the drum, of if it does, I have never ever seen that in any machine that i have worked on, even high mileage ones.
                  Alan, fix where he cut something off could be something to look into. He is kinda crazy, but hey, if he found a fix, well it's a fix.
                  Don't know this machine myself , but the problem is such, that so many various conclusions, but the majority points to the dev,
                  Who else has a take on this.
                  I remember working on a kyocera fs3560 and it had a high pitch squeeking noise . I lube every bloody thing on that machine, pinch gears, bushing , only for it to com back with the squeek. I was determined to find the source. The only thing left was the transfer roller bushing, and I don't usually lube those, just clean as part of normal maintenance. Well I put a drop of tri-flow oil on it and the noise went away. Also the registration roller pinch roller bushings too make noise sometime.
                  • ayeright
                    • Feb 2011
                    • 74
                    #39
                    I enjoyed the thread especially for the idea of 20+ year tech's being considered oldies
                    20 year techs are newbies to some of us
                    • Muso
                      • Oct 2022
                      • 13
                      #40
                      Thanks Sir for your reply. I agree that Alan fix is a kinda crazy)). To cut the springs and there is no explanation how much need to cut. And if you cut the springs and the pressure reduse more than needed you may have printing problems (pale printouts). But as he mentioned for him this solution worked. Sharing your experience working with Kyocera can tell that some issues and fixes can be that you never think off)). So what I did replaced this two spacer(round white plastic) from both side of the transfer roller and will be monitoring the drum. But the drum is already a little bit scratched. If the scratch will not increase than I can be sure that the issue is resolved. Otherwise I will hang myself in front of this copying machine))).
                      • Muso
                        • Oct 2022
                        • 13
                        #41
                        ))) Exactly.
                          • 23010
                          #42
                          LOL!! =^..^=
                          • subaro
                            • Oct 2010
                            • 1274
                            #43
                            As I said before, I don't know that machine, but just working by the priciples of copier/printer basic mechanics. The transfer roller springs IMO, should never be cut or modified, as you also mentioned. It has the right enough tension, even it looses a bit in age, it should not be a problem.
                            A question though. When you guys say you replace the drum, is it the entire assy or just the drum itself.
                            The assy , as far as I see from the parts manual, has the charge grid and wire, the cleaning blade and the recovery blade. I see, most replace the cleaning blade and not the recovery blade. The recovery blade also gets worn and leaks toner, which gets onto the drum and then it drops on the charge grid. There is also the felt, that the drums sits on the ends that gets worn and needs to be replaced.
                            Panasonic drums use to have these kind of issues as the entire drum parts had to be replaced or you would get all kind of symptoms, of toner leakage and lead to all kind of problems, if they were not rebuilt properly.
                            Me, I stil think the problem is in that drum unit. The spaces do not rotate. The transfer roller rotates and the inside of the spacer has to be worn for the spacer to be a problem. This is my theory anyway.
                            Let us know your results as you mention.
                              • 23010
                              #44
                              As I said before, I don't know that machine, but just working by the principles of copier/printer basic mechanics. The transfer roller springs IMO, should never be cut or modified, as you also mentioned. It has the right enough tension, even it looses a bit in age, it should not be a problem...
                              I tend to agree with you. I've had transfer roller springs go missing ... and I've had to choose a replacement from my miscellany of springs ... but I've never tried to alter the transfer roller pressure.
                              ... A question though. When you guys say you replace the drum, is it the entire assy or just the drum itself. The assy , as far as I see from the parts manual, has the charge grid and wire, the cleaning blade and the recovery blade. I see, most replace the cleaning blade and not the recovery blade. The recovery blade also gets worn and leaks toner, which gets onto the drum and then it drops on the charge grid. There is also the felt, that the drums sits on the ends that gets worn and needs to be replaced.
                              These drum units only come from KM as an assembly, but there are aftermarket sources for drums & blades. And yes, in my experience the biggest problems with drum units are the result of a poorly performed rebuild. Specifically there is a positioning adjustment for the drum within the assembly, and if it's not correct the developing roller spacing will be wrong, the charge wire spacing will be wrong, so one side or the other side of the image can be light if that rebuild is done incorrectly. IMHO the savings from replacing individual components in a drum unit are not worth the poor final results. =^..^=
                              • tsbservice
                                Field tech
                                • 8041
                                #45
                                I have seen this but drum damage was outside image anyway and drum unit was over life and changed. Transfer roller also regularly changed, will check pressure next time.
