PRO 951 message "Plase close the front door"
  • ysshin79
    • May 2017
    • 37
    [Dead] PRO 951 message "Plase close the front door"
    Hello.
    I am Korean.
    I'm writing on a language translator, so I'm not sure if it will be delivered properly.
    I'd like to ask you a question.
    The warning "Please close the front door" will be displayed on both of the 951s.
    And there's something in common. Both of them have severe internal dust contamination.
    1 - DCPS/2 Disassembly Assembly and Illumination
    1 - Exterior cover and interior simple dust cleaned and lit
    I'll write down my replacement.
    1 - Front door Photo Sensor 2EA
    2 - Check Fusing Unit Connecter
    3 - Replace ADUDB
    4 - DCPS/1 and DCPS/2 Replace
    5 - Check Fusing Unit Connecter on the back of the body
    6 - Cleaning the ADU connection connector
    If you have any experience, please ask me a favor.
    Have a nice day.
    Thank you.
    • 23007
    Re: PRO 951 message "Plase close the front door"
    Originally posted by ysshin79
    Hello.
    I am Korean.
    3 - Replace ADUDB
    Have a nice day.
    Thank you.
    Have you checked to see if your door switches are getting the supply voltages?
      • 30188
      Check the finisher doors as well or disconnect and see if problem goes away
      • allan
        RTFM!!
        • 5462
        Check ICP's.
        Blew a board 2 weeks ago. First in years. Plunged the finisher in on the wrong connector and got similar results.
        Lucky its was only an ICP.
        Whatever
        • ysshin79
          • May 2017
          • 37
          Thank you for replying to BLACKCAT4866.
          I haven't checked the voltage. I'll try. Thank you.
          Before I post, Bsm2, I did it without finisher.
          Thank you for your reply, I'm sure you are busy.
          Thank you allan for your advice.
          Let me check if there is an ICP defect.
          Have a nice day.
