DEVELOP DRUMS 1060/1070
  • xeroxsharp
    • Nov 2008
    • 270
    Hi all,
    I am a Xerox tech and I wonder, what is the difference between DRUMS develop drum DU105 and DU106.
    Thanks to all.
    Regards,
    Mitja
  • Synthohol
    Certified Konica Expert
    • 5905
    Re: DEVELOP DRUMS 1060/1070
    there is likely a flange and or hardware difference and could also be the coating of the drum as well.
    for the price i woulnt risk it. id get whatever the machine calls for.
    • xeroxsharp
      • Nov 2008
      • 270
      Thanks Synthohol. My opinion is exactly the same.But I'm still interested in some other opinion.
      Thanks again.
      • Gaffers01
        • May 2011
        • 335
        The plate at the backend of the drum is different, just swap it with old one and it works fine.
        Takes about 10 minutes to do.
        • wjurls
          • Feb 2017
          • 505
          I convert DU-105's to DU-106's all the time. It takes 3 seconds with a pneumatic muffler cuttoff wheel.
          I have attached photos. This process will save you about $100 each on a C1060L.
          • mastarad
            • Sep 2011
            • 34
            du 105 drum life 1060 2070 3070
            hello,
            what is a real life of your du-105 drum? 100% is 410.000 copies. who print more, who print less?
            • xeroxsharp
              • Nov 2008
              • 270
              Thanks to Gaffers01 and wjurls .
              • wjurls
                • Feb 2017
                • 505
                Re: du 105 drum life 1060 2070 3070
                [QUOTE=mastarad;764935]hello,
                what is a real life of your du-105 drum? 100% is 410.000 copies. who print more, who print less?[/QUOTE
                They can make it to around 180%, 165% average, I would order replacement to keep on hand around 150%.
                • jpablo_mza
                  • Jun 2018
                  • 30
                  [QUOTE=wjurls;779668]
                  Originally posted by mastarad
                  hello,
                  I had to change two sets of Du105 with 100k for lines in the print, apparently it is due to a manufacturing defect, the manufacturing date is 01-19.
                  You who should be this possible
