C284e dead
    • 14850
    #16
    Re: C284e dead
    Sometimes if the metal paper guide assembly inside the tray shifts backwards it will cause paper size errors. Make sure the two screws are centred.
    • mrfuser
      • 1622
      #17
      Re: C284e dead
      Do you know what the sensors are actually called in the parts manual?
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        #18
        Re: C284e dead
        Generally they are called size detect sensors.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • allan
          RTFM!!
          • 5462
          #19
          Re: C284e dead
          Dude pull out a tray get on your ass and have a look in there. Try opening a parts manual.
          Whatever
          • mrfuser
            • 1622
            #20
            Re: C284e dead
            Dude! 🤪😂
            thanks I needed a chuckle!
            • mrfuser
              • 1622
              #21
              • copierdude1114
                • Dec 2015
                • 29
                #22
                Re: C284e dead
                Problem
                MFP may stop at 2 bars, 4 bars or KM logo.
                Solution
                CAUSE: Poor communication between MFPB and other components "Finisher, Network and fax cables, DSIPB, HDD and PRCB".
                SOLUTION: Please perform the following steps.
                1. Start with disconnecting the following components from MFP "Finisher, Network, fax cables and HDD" and see if machine can take the latest firmware.
                2. Disconnect the Printer control board (PRCB) from MFP board (MFPB) (PJ03 on MFPB or CN41 on PRCB) as well as the Dual scan image process board (DSIPB) and see if the machine will boot.
                3. If the MFP boots, you can get into service mode by pressing on "Menu" button to bypass the error code screen then touch "Counter" to enter Service Mode and check for trouble codes to help troubleshoot.
                4. To access service mode touch Counter-> Display Keypad then enter Stop00 Stop01-> Enter CE Password (default 9272 4x).
                5. If the machine boots, reattach all the components that were previously disconnected to see which one causes the issue.
                Technical Notes
                All that is required to boot the MFP board is the display, touchscreen, SSD board, memory, and power.
                • mjunkaged
                  • 386
                  #23
                  Re: C284e dead
                  Yea, I'm old and it HURTS when I do it but I still do it!!!!!
                    • 14850
                    #24
                    Re: C284e dead
                    Go into service mode and check the level on the SSD. If it isn't at 6.05 you will need the recovery firmware. If that doesn't work you may need a new SSD board.
