C284e dead
  • mrfuser
    • 1613
    C284e dead
  • mincopier
    • Dec 2015
    • 289
    Re: C284e dead
    NVRAM.
    • mrfuser
      • 1613
      Re: C284e dead
      Will firmware fix this?
      Originally posted by mincopier
      NVRAM.
        • 14520
        Re: C284e dead
        If it is the SSD causing the problem there is specific firmware. Although it may not help if it is not booting.
        • mrfuser
          • 1613
          • mrfuser
            • 1613
            • mrfuser
              • 1613
              • Woxner
                • Jul 2011
                • 839
                Re: C284e dead
                go into service and under part isolation turn the tray back on
                • mrfuser
                  • 1613
                  • allan
                    RTFM!!
                    • 5462
                    Re: C284e dead
                    ??? means it is between sizes. Remove the tray and check the slides on the tray and the sensors at the back inside the machine.
                    Set both trays the same and compare the sensor checks.
                    Whatever
                    • Zesti
                      • Jun 2009
                      • 308
                      Re: C284e dead
                      Fuser u'r sooooo lucky..I'm facing same problem in a C554e.....no luck so far....same symptoms of sticking at 2 fins..
                      Good for you...
                      • Zesti
                        • Jun 2009
                        • 308
                        Re: C284e dead
                        Good for you...
                          • 14520
                          Re: C284e dead
                          If you have access, you should install SSD repair firmware. It may keep this problem from happening again.
                          • mrfuser
                            • 1613
                            • allan
                              RTFM!!
                              • 5462
                              Re: C284e dead
                              Don't just take a tray take the length and with sensor/switch assemblies too. The sensor holder can break.
                              Whatever
