bizhub web solenoid not working
  • Gulbadin
    • Nov 2017
    • 22
    bizhub 600 web solenoid is not working.
  • allan
    RTFM!!
    • 5462
    Re: bizhub web solenoid not working
    Hehe you need to reset the web counter to get it to run again.
    Whatever
    • Gulbadin
      • Nov 2017
      • 22
      i have done that but no luck
      • copyman
        Owner / Technician
        • Sep 2005
        • 4657
        These stupid questions have to be asked: Are you sure you have the rollers in right? Did you take the cleaning roller assembly out and move lever to make sure gears turn and move roller properly?
        Like the other post with resetting the counter, did you reset to "0" or "250,000". It should be set to "250,000" because it counts down if not mistaken? And if set to "0" it will never move!
        • methogod
          • Dec 2008
          • 920
          also if i remember correctly you have to turn off mains power and restart for it to count again.
          • mincopier
            • Dec 2015
            • 289
            As old as the BH600 is the solenoid could just be bad. There is a I/O check in the manual that turns this off/on manually.
