Bizhub C364e Jumps to Admin setting password when you select Utility button
  • captainrva
    • Oct 2014
    • 100
    When I select the Utility button, it prompts for Admin password. I have looked around the security settings and tried a few things but I've had no luck. Any help is appreciated.
    Edit: I have formatted the SSD, HDD, done a clear all data, and firmware update to latest release.
  • Synthohol
    Certified Konica Expert
    • 5825
    Re: Bizhub C364e Jumps to Admin setting password when you select Utility button
    In service mode hits stop 0 clear make sure under management function choice that Unset.is selected
    Let us know.
    • tsbservice
      Field tech
      • 8016
      I may be wrong but seems to recall that users can be prevented to use Utility button.
      Can't find now how, though.
      • Synthohol
        • 5825
        there is no more utility button, its "home" now.
        • tsbservice
          Field tech
          • 8016
          That's right, my bad, i was thinking about Utility menu but wrote button.
          captainrva, what do you need to do, can you use web interface?
          • rrrohan
            • Sep 2011
            • 1977
            I though a soft switch could be set to need password for user mode. Never used it so maybe it locks out the entire section.
            Could explain when initialisation did not help
            • gere1
              • Oct 2018
              • 20
              check that SW switch 71 being set to 00
              • captainrva
                • Oct 2014
                • 100
                Let us know.
                Unset was already chosen under Stop 9
                SW switch 71 was already set to 00.
                • captainrva
                  • Oct 2014
                  • 100
                  I still have no idea how to fix this. Should I just use the reset tool?
                  • tsbservice
                    Field tech
                    • 8016
                    Check that DIP switch 200 (bit 5) being set to 00.
                    There may be other SW settings related, but first check this.
                    • copier tech
                      • 8144
                      Try SW switch 200 set to HEX 20
                      • tsbservice
                        Field tech
                        • 8016
                        Just checked this on C224e machine. Default settings of HEX is 00(didn't ask for password), setting it to HEX 20 - it asks for admin password when Utility is pressed.
                        • captainrva
                          • Oct 2014
                          • 100
                          That did the trick! SW switch 200 was set to 20 so I changed it to 00 and no more password prompt to get into Utilities. Thanks!
                          • copier tech
                            • 8144
