C454 Printing streaks on first pages.
  • dcat127
    • Feb 2010
    • 19
    I have a c454 that is printing streaks, whenever it has been sitting for an hour or so. After printing about 25 pages it goes away. See attached example, it is most visible in the lower right hand corner.
    I have already put in new imaging units(all colors), and changed the transfer belt unit.
    I would appreciate any thoughts you might have.
    Re: C454 Printing streaks on first pages.
    print or copy?did you clean the machine ?
    what about the developer units?
    total page count on machine?
    • copier tech
      • 8174
      Are you using genuine toner?
      • dcat127
        • Feb 2010
        • 19
        print or copy? Both
        did you clean the machine ? You mean vac out any spilled toner? Or is their a cleaning cycle I am not familiar with?
        what about the developer units? Only black has been changed, but it appears that this is black toner...
        total page count on machine? 1.2 million
          print or copy? Both
          yes vac out and clean w/ stretch n dust cloth
          is it BLACK or grey (mixed waste toner)
          did you think to look at the FUSER?
          • JR2ALTA
            • Feb 2010
            • 2033
            Odd, It sure looks like the transfer belt blade isn't cleaning well. I see a mixture of color, some yellowish but maybe that's the file.
            I know you replaced the unit, does this machine have a waste cleaning system that can back up into the unit, or maybe just spill over in general?
              • 23009
              print or copy? Both
              Please excuse my pointing out this inconsistency: Firstly this series of machines uses separate drum and developing units, so technically there is not a single image unit and you could not have changed all of them if they don't exist. Then in the next post you changed only a black developing unit. This fault is by all appearances a worn black drum issue (since you're a bit unclear on this: yes drums and developing units are different).
              So did you or did you not change the black drum?
              I did look at your scan. The area of background is definitely ~3% K only. That could be because you scanned in B&W or because the problem is with the black drum. There is no way for me to distinguish.
              Keep in mind that transfer waste is more brown colored IF you do a lot of color printing. If you do all black printing the transfer waste will be mostly black. =^..^=
              • 3ktlc
                • Feb 2018
                • 180
                check the fuser
                • allan
                  RTFM!!
                  • 5462
                  Did you initialize the transfer belt so that it gets primed. This machine will flip the cleaning blade if that is not done.
                  News on the condition of the K drum?
                  Change it out with one of the color drums to test.
                  Whatever
                  • copier tech
                    • 8174
                    Well ?
                    • dcat127
                      • Feb 2010
                      • 19
                      Yes
                      • dcat127
                        • Feb 2010
                        • 19
                        Sorry, my mistake. All the drums have been changed, and the black developing unit.
                        • dcat127
                          • Feb 2010
                          • 19
                          Thanks for everyone's replies. After looking at it closer I am convinced this is an issue of the wiper blade not cleaning the transfer belt properly. I removed the transfer belt unit, you can clearly see some toner, and what looks like some kind of fuzz stuck between the wiper blade and the belt at the exact spots that the streaks are coming from. After I cleaned all that out and put back together it prints fine. However I let it sit overnight, the first copies out of the machine again show that streak...
                          • copier tech
                            • 8174
                            When you you replaced the transfer unit did the line return in the same place?
                            • dcat127
                              • Feb 2010
                              • 19
                              I am not 100% sure. It actually disappeared for maybe 20k copies before returning.
