DF bizhub C280 adjustment
  • Bix
    • Apr 2018
    • 1421
    Hello,
    I have a bizhub C280. When I scan via DF, a black mark goes out in the lower right corner. I think it's due to a wrong setting of the DF. Do you advise me to adjust through the screws or is there any option in the Service Mode?
    Thank you in advance
    • 23010
    Re: DF bizhub C280 adjustment
    I think a sample might be helpful. =^..^=
    • Bix
      • Apr 2018
      • 1421
      Hi, the strip has been removed by adjusting the screws of the DF. Now the scan is good enough.
      At software level via Service Mode, perhaps there will also be something for eventual margins/inclination (?)
      • Synthohol
        Certified Konica Expert
        • 5868
        non image erase adjustment.
        then adjust feeder with the black box sheet.
        • Bix
          • Apr 2018
          • 1421
          If I threw that piece of paper I'll never be able to recover it ??
          • JR2ALTA
            • Feb 2010
            • 2033
            They come with new machines. Also the part number is A7829450-02
            • Bix
              • Apr 2018
              • 1421
              Yes, thank you very much
