KM Bizhub C364e - Image Quality Block Colours
  • insigniawales
    • 29
    Hi - I have a problem with a machine on block colours (not C,M,Y,K) I'm having Yellow/Cyan/Magenta Lines within a block of Grey / Orange / Green etc. I think its related to the drum units. No P-Codes displayed machine on 500k, Cyan and Magenta drum life near end (10%) 80BD6809-F41F-4BED-84B2-802640A8CE4D.jpg
    Many Thanks -
    Re: KM Bizhub C364e - Image Quality Block Colours
    Originally posted by insigniawales
    Hi - I have a problem with a machine on block colours (not C,M,Y,K) I'm having Yellow/Cyan/Magenta Lines within a block of Grey / Orange / Green etc. I think its related to the drum units. No P-Codes displayed machine on 500k, Cyan and Magenta drum life near end (10%) [ATTACH=CONFIG]41513[/ATTACH]
    Many Thanks -
    well you just stated the NEXT step... replace the M & C PCU
      • 14812
      Clean the grids with the pull out wands and test again. If still no good replace colour drums.
      • Synaux
        • Mar 2012
        • 1224
        Perform CMYK gradation & halftone tests. Then replace IUs a necessary.
          he will have to rerun adjustment after installing new IUs wont he?
          • insigniawales
            • 29
            Many thanks for your contributions very much appreciated.
            • tsbservice
              Field tech
              • 8020
              What about posting consumables life? Dev units especially.
              Print one color gradations etc. in service mode. What is done by techs?
              • insigniawales
                • 29
                I will post these up tomorrow for you roughly 25% life on Devs will post gradiation c m y k etc
                • copier tech
                  • 8174
                  Many Thanks -
                  Are you new to this industry?
                  Run gradation prints for each colour this will point you in the right direction.
                  Dev units look ok but not enough to see from your sample.
                  • Bix
                    • Apr 2018
                    • 1421
                    But has the Develop already been replaced at least once? Usually towards 600k
                    • Synaux
                      • Mar 2012
                      • 1224
                      Test prints, not adjustment! haha :P
                        Sounds strange.
                        Most time when installing new pcus you have to adjust bias settings..
                        And WHY the fucking haha?
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4721
                          Yeah I'm with Phil I don't get it. The drum with new chip resets count and adjusts / stabilizes automatically. But still should do manual "adjustments" when any consumables are replaced, Gradation adj, etc.
                          • Synaux
                            • Mar 2012
                            • 1224
                            You don't get what? I merely suggested to perform test prints out of SM to identify exactly what IU(s) need to be replaced (which was suggested by copy tech as well). Depending on the situation, and PQ requirements, he might only need to replace 1 IU (as well as clean the PH as suggested).
                            You guys are confusing the hell out of me lol
                            • insigniawales
                              • 29
                              Replaced 3 Drums Today - Cyan Magenta and Yellow
                              Many thanks for your comments and suggestions.
                              Good to know for any other engineers experiencing same problem.
