PM COUNTER Konica minolta xx4 e cxx4 series
  • enricocopyline
    • Jun 2018
    • 129
    good morning,
    I wanted to know if it was possible to lock the machine when it arrived at a certain PM counter?
    I saw that it is possible to stop it when the consumables are reached, but I do not know how to set it to stop it when a count set by me is reached
    • 15069
    Re: PM COUNTER Konica minolta xx4 e cxx4 series
    Originally posted by enricocopyline
    good morning,
    Go into service mode-counters-maintenance counter. You can set a number there. I never use this so I don't know if it will disable the machine when the count is reached, or simply show a message that maintenance is required.
    • enricocopyline
      • Jun 2018
      • 129
      in this way it only displays the message but the machine does not stop.
      thanks
      • allan
        RTFM!!
        • 5462
        There is a soft-switch that will disable the machine if the count is reached.
        Does anybody have a SW list for these machines?
        Whatever
          • 15069
          thanks
          I can't help but wonder why you want the machine disabled at a certain count. Hopefully not to generate service calls.
          • enricocopyline
            • Jun 2018
            • 129
            I need to know why I have a machine that is blocked with the pm counter I would like to know how to unlock it without having to reset the counter every time.
            does anyone have the sw list for these machines?
            • allan
              RTFM!!
              • 5462
              SW 51 F0
              SW 55 0C
              It will suck developer if you don't keep an eye on it...
              Whatever
                • 15069
                Back up address book and network settings and do a total clear. That will take it back to factory default
                • copier tech
                  • 8236
                  Rubbish why would he want to do an all clear!?
                  Image unit & dev counts are stored on the iu chip you can enable or disable "life stop" in CE mode.
                  You can clear the transfer & fuser counts in CE mode Counter "new release"
                  • Synaux
                    • Mar 2012
                    • 1224
                    Rubbish you say?!
                    As far as I can tell, this has nothing to do with any consumable counters.
                      • 15069
                      Rubbish right back at you! Lol. There are no counts stored on drum or dev chips. When the chip clears the counter the machine starts to count, not the consumable. I have tested this by simply taking a drum from one machine to another and the count does not follow. Having said that, yes you can turn disable life stop in service mode.
                      • copier tech
                        • 8236
                        Originally posted by Synaux
                        Rubbish you say?!
                        Well poster is referring to PM counters, image units can be set as PM items or consumables.
                        • copier tech
                          • 8236
                          So if I was to take an old image unit & fit it into a new machine this machine will not show up as an old drum in consumable life but will display as new? (Previous IU life)
                            • 15069
                            Correct
                            • Synaux
                              • Mar 2012
                              • 1224
                              Correct
                              I surely hope I am misunderstanding something here.
