PM COUNTER Konica minolta xx4 e cxx4 series
  • tsbservice
    Field tech
    • 8020
    #16
    Re: PM COUNTER Konica minolta xx4 e cxx4 series
    Wait....
    The topic starter only wants firmware, counters reset and this kind of sh.. Read his posts, there aren't many.
    Why knowledgeable gyrus have to waste their time?!
    • enricocopyline
      • Jun 2018
      • 122
      #17
      Originally posted by allan
      SW 51 F0
      SW 55 0C
      It will suck developer if you don't keep an eye on it...
      I wanted to know what is the bit to be set to 0 or to 1 to restart the machine of the sw No 55 or 51 I think from what I know
      • copier tech
        • 8172
        #18
        • enricocopyline
          • Jun 2018
          • 122
          #19
          55 bits 3 and 2 refer to the belt and fuser
          51 the bit
          7 to the fuser
          6 belt
          5 dev
          4 drum
          PM? what bit?
          I would like to stay all as it is now just remove the pm counter
          • allan
            RTFM!!
            • 5462
            #20
            Chips only contain a fuse that resets the counters. So i have been dead shorting or replacing the fuses to reset the units.
            The older ranges had a more intelligent chip on it. Use to rewrite them with the original data to reset them.
            Again use 51 F0 and 55 0C hex values to do it in one go.
            Whatever
            • CompyTech
              Super Tech
              • Feb 2011
              • 706
              #21
              On the 4e series consumables like drums, transferbelt, fuser etc are set to display end of life messages by default and continue to run without shut down. We usually turn off the end of life messages to display during setup. The only thing that will still display end of life messages is the transfer roller and toner and ozone filters, but these can easily be reset. On the older earlier 4 series this is not the case and the machine will shut down when end of life is reached, you will have to use the software switches to disable the notifications and allow the machine to continue to run - found out the hard way about that one.
              There are custom PM counters in the service mode that can be setup but I have never messed with those.
              • rrrohan
                • Sep 2011
                • 1977
                #22
                Reminds me of the old key counters customers would plug in to unlock copier. Once they used the set amount copier could not be used again until the purchased more.
                Almost sounds like this is what OP is trying to force. Don't pay and your copier is disabled
