Bizhub 363 supply settings HP Web Jetadmin / FW ?
  • wrose51106
    • 7
    Hello everyone -
    I am attempting to monitor some Konica Bizhub 363's in HP Web Jetadmin software. The software is up to date. I have 2 locations, in location A tray 1 and 2 show supply levels only. In location B tray 1 and 2 also show, but so do drum, fuser, toner, itb and cleaning kit. I would assume the FW in location A is out of date? The local dealer says it is, I think they might be fibbin. Can anyone shed some light on this?
    ROM Version
    MFP Controller BOOT Program A1UD0Y0-1E00-G00-02(00)
    MFP Controller SubSet A1UD0Y0-1F00-G00-04(00)
    MFP Controller A1UD0Y0-0100-G00-D6(00)
    Operation Panel Message Data A1UD0Y0-8100-G00-D4-00
    Fax Board Controller1 A22M0Y0-4000-G00-06(00)
    Fax Board Controller2
    Scanner A1UD0Y0-0023-G91-0F
    Printer A1UD0Y0-0050-G00-15
    ADF A1430Y0-0024-G00-12
    Finisher A0HR0Y0-0071-G01-07
    Panel CPU A0P00Y0-8900-G00-00
    DSC1
    DSC2
    LCT
    Loadable Device Driver
    SD
    Voice Data
    Movie Data
    Dictionary Data
    OCR Library
    MFP Controller System A1UD0Y0-1000-G00-D6(00)
    MFP Controller Print Controller A1UD0Y0-3000-G00-67
    MFP Controller Print Controller Font A1UD0Y0-3F00-G00-0D
    MFP Controller Print Controller Demo Page A1UD0Y0-3E00-G00-00
    MFP Controller MIO A1UD0Y0-5000-G00-09(00)
    MFP Controller PSWC A1UD0Y0-5100-G00-10(00)
    MFP Controller MIB IF A1UD0Y0-5200-G00-00
    MFP Controller IPP IF A1UD0Y0-5200-G00-00
    MFP Controller Outside Controller IF
    MFP Controller TCP/Socket A1UD0Y0-6300-G00-21(00)
    MFP Controller OPEN API A1UD0Y0-7000-G00-13(00)
    MFP Controller Operation Panel A1UD0Y0-8000-G00-D6(00)
    MFP Controller CSRC Control Body A1UD0Y0-8300-G00-01
    MFP Controller PIC A1UD0Y0-8200-G00-A5
    • 14815
    Re: Bizhub 363 supply settings HP Web Jetadmin / FW ?
    The most current base firmware for the BH363 is G00-D6, which you have. There is likely some special firmware that is more recent, but it is only needed to correct specific issues.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      Agree with copier addict.The "latest" F/W for that old model is from 2012 !
      • Woxner
        • Jul 2011
        • 851
        end of life ius 2022
        • wrose51106
          • 7
          Thank you all.
          Any idea why only the trays are showing up in HP? All machines have the default SNMP v1 public / private.
            Originally posted by wrose51106
            Thank you all.
            maybe not all Admin settings.tabs are setup?
            been too long for me to wipe cob webs
            • allan
              RTFM!!
              • 5462
              Have you re-flashed the machine?
              Initialize the machine.
              Think your MIB could be not the right one or the original.
              Or the thing reading it is restricted from getting to it or certain parts of it. Could be private.
              Could be a security setting.
              Check all SNMP and MIB related stuff.
              Try doing it with KM software. Pagescope net care.
              Whatever
              • wrose51106
                • 7
                Go on, I am not familiar with this at all.
                No I have not, we have about 30 at location A.
                I have all machines on DHCP reservations and address books backed up, not a deal breaker to restore them. Local dealer might have a fit, cant blame them. I will need to locate a how to on initializing the 363.
                I have a hard time thinking all 30 could be corrupted.
                I thought this as well, I can not find anything to even remotely point to it though through the web interface or the local admin screen.
                Done and done, it is set correctly, or the trays wouldn't read. We use SNMP v1 public on all print devices.
                I will need to load a copy Monday to test.
                Thank you all for the ideas!
                • allan
                  RTFM!!
                  • 5462
                  No idea it was 30 units. Then really don't think its the machines at all.
                  Whatever
                  • wrose51106
                    • 7
                    I went through stop - 0 - 0 - stop - 0 - 1
                    Under system 1 - I did an initialize. It did not fix the issue.
                    • wrose51106
                      • 7
                      When I go into admin settings, different machines have different tabs available, like there is supposed to be 10 tabs, 2 -5 - 8 - 9 are not available, is this what you mean?
                      • wrose51106
                        • 7
                        ROM Version
                        DSC1
                        DSC2
                        LCT
                        SD
                        Voice Data
                        Movie Data
                        Dictionary Data
                        OCR Library
                        Here is the ROM info from the one that does report.
                        ROM Version
                        Scanner A1UD0Y0-0023-G00-0D
                        Finisher
                        DSC1
                        DSC2
                        LCT 4348000-0050-G00-02
                        SD
                        Voice Data
                        Movie Data A1UD0Y0-A000-G00-00
                        Dictionary Data A1UD0Y0-B000-G00-0000
                        OCR Library
