How to Wrap Scanner Cables on a C284e
  • guycampo
    • Aug 2015
    • 6
    Hello:
    I'm looking for info on how to wrap scanner cables on a C284e. The service manual does not provide any info. Nor does KMBS support.
    Thank you,
    GC
  • Albonline
    • Sep 2008
    • 1151
    Re: How to Wrap Scanner Cables on a C284e
    Originally posted by guycampo
    Hello:
    Thank you,
    GC
    take a photo of a good one and follow it.
    • escalante
      • Sep 2018
      • 115
      Good afternoon. to see if this section of the parts scanner is useful1.10 SCANNER SECTION.pdf
      Enviado desde mi SM-J701M mediante Tapatalk
        • 23009
        That was my suggestion. Find a good scanner to snap some shots of. Focus on the wire rope drums (counting number of turns), and the routing of the wire through the pulleys. There was a time when we re-strung scanner cables in beginners class. =^..^=
          yeah THANKS BC.. nitemares of that and coronas class! UUUgghhhhh
          • NeoMatrix
            Senior Tech.
            • 3513
            Oh so much fun.... especially realtime in the field when you have nothing to compare too.
            Darn the scanner frame is skewed 45deg. So... undo all the wire cable routing an try again.
            • Synaux
              • Mar 2012
              • 1224
              Hello:
              Thank you,
              GC
              Jebus....you just revived the thing nightmares depend on!
              But yeah follow a working machine and be very careful it is easy to get the cable caught on something and rip the plastic coating off the cable (that is, if the cables have the same coating as the prior models).
              • allan
                RTFM!!
                • 5462
                A helping hand will be handy. Could not do it alone on a C360.
                Whatever
