Konica Minolta C654e HDD error related to firmware
  • copier tech
    • 8174
    #16
    Re: Konica Minolta C654e HDD error related to firmware
    Originally posted by Synthohol
    well damn, looks correct.
    konica is finicky with some USB drives like some sandisk ones and others. i would only use 4gb or less for best results.
    some drives have a hidden partition and those fail as well.
    heres some incompatible drives from previous models, and the list has only gotten bigger im sure.
    Solution
    CAUSE: In most cases, the message is not related to the USB memory device itself. The message normally indicates that the firmware on the USB memory stick is not applicable to the model to which the firmware update is being performed.
    SOLUTION: Check if the firmware on the USB memory is the correct version and type for the model. If not, download the right firmware onto the USB memory and retry the firmware update. If the same message is displayed again, try another USB memory device that is known to work.
    C654e C754e_A2X00Y0-F000-G20-M0.exe is the FW you need. its A2X00Y0 and your pic shows A79J in one of the files.
    In The UK the latest available fw is version for the C654e & C754e is: A2X00Y0-F000-GDG-M0
    MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB now
    • Synthohol
      Certified Konica Expert
      • 5849
      #17
      Release Notes: bizhub C654e, C754e (LK-101) Special Firmware Version GDG-M0 FA14 and PKI card invalid message correction
      thats not the latest base FW, that was under special FW to correct a PKI issue.
      C654e C754e_A2X00Y0-F000-G20-M0.exe is the newest base FW.
      • Famoosa
        #18
        where can i find or download the firmware? have been looking all overt the internet and unable to find it
        • copier tech
          • 8174
          #19
          • antone
            • Oct 2014
            • 344
            #20
            Konica.com
            Sent from my SM-N950U using Tapatalk
            • Famoosa
              #21
              Originally posted by antone
              Konica.com
              Tried them directly but but they only have the printer drivers no firmware available for download, if someone could assist urgently it would highly appreciated. Thank you in advance
