Repaired MFPB c368
  • arahael
    • Mar 2013
    • 97
    Repaired MFPB c368
    Hello. I ordered refurbished mfpb for c258. After replace board swapped eeprom1/2, emmc, enter correct machine type, used reset tool, update firmware/boot, machine dropping c163/c164, any sugestions ?
  • kingarthur
    • 1375
    Re: Repaired MFPB c368
    If the codes are CC163/CC164 , the manual says wrong model of FW, the machine type information registered to the machine differs from the actual machine type
    • qbert69
      • Mar 2013
      • 1152
      Error Codes > Konica-Minolta > bizhub 130f > page 1 C368&code=CC163
      Error Codes > Konica-Minolta > bizhub 130f > page 1 C368&code=CC164
      Apparently something is not quite right!!![emoji848]
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • arahael
        • Mar 2013
        • 97
        I send back mfpb. Data on MFPB can be corruped. I must wait to resend new. Thanks
        • byronf
          Senior Member
          • Sep 2017
          • 109
          I am also stuck with the same issue, I have replaced mfp board, emmc & EEPROM but the issue still persist's. The only thing I haven't try was the reset tool, do you mind sharing it with me please.
          • Synthohol
            Certified Konica Expert
            • 5854
            1. This error may occur after flashing the MFP firmware. It signifies a ROM contents faulty error due to incorrect or corrupted firmware being installed.
            Reinstall the firmware verifying that the firmware file and checksum corresponds to the correct machine. The latest version firmware or system software is available via the Konica Minolta Download Selector.
            This error may occur intermittently after replacing PWB-MFP. It is possible the ribbon cable on PWB-MFP was not fully seated.
            Remove and reseat the ribbon cable on PWB-MFP.
            double check the machine type based on the serial# not the model.
            bit sw 25 settings based on serial.
            • escalante
              • Sep 2018
              • 115
              In this photo, it refers to the code CC-163 and CC-164
              Enviado desde mi SM-J701M mediante Tapatalk
              • arahael
                • Mar 2013
                • 97
                i can't find gg9 firmware anywhere. also on my infohub. can you?
                • Synthohol
                  • 5854
                  Version GG9-84 under special FW
                  bizhub C258, C308, C368 Special Firmware Version GG9-84 Boot ROM Version G00-02 and Screen calibration
                  • arahael
                    • Mar 2013
                    • 97
                    I can't find anywhere ffs Im using DEVELOP dbox site its makes me sick to find anything mate.
                    • canerk
                      • Apr 2019
                      • 5
                      • canerk
                        • Apr 2019
                        • 5
                        GG9-84 yazılımı nereden bulabiliriz.
                        • canerk
                          • Apr 2019
                          • 5
                          • tulintron
                            • Jul 2014
                            • 668
                            Good morning. By the way, did you try to change the speed up of the equipment?
                              the rest of the posts here are in english...
                              could you be so kind as to follow the leads of other?
