CQ issue C552 ?
  • Sam Tofu
    • Dec 2007
    • 130
    CQ issue C552 ?
    Mainly work on Sharp, Ricoh and Kyocera. Have manual for this but not finding adjust/calibra for issue.
    Issue: On platen glass copy is correct density. Print Engine density correct. However, when scanning the copy is about 3 stops lighter. Glass is clean etc. Only seeing adj for trail lead, magnification etc. not seeing anything re density.
    TIA!
    Re: CQ issue C552 ?
    TIA!
    glass is clean.. ok slit glass and white plate too?
    you are lookin for copy density adjust.. not ADF
    g
    • Woxner
      • Jul 2011
      • 853
      Re: CQ issue C552 ?
      shine a flashlight on the mirrors. if you have not clean them do so. the position under the slit glass verses the scan distance is different.
