C35 scanner unit replacement
  • copier tech
    • 8142
    Hi all,
    I have to replace a broken glass/scanner unit on this old little machine, any tips & time scale to allow!?
  • avecosat
    • Jun 2012
    • 305
    Re: C35 scanner unit replacement
    I have changed many units and it is very simple, I have even exchanged with the bh36. Are you going to change the unit or just the belt?
    • copier tech
      • 8142
      Complete scanner ass'y, my colleague has removed one from a scrap machine & is shipping it out to me!
      • Albonline
        • Sep 2008
        • 1147
        be careful of pinching wires during reassembly, this is the most common problem i see.
        • srvctec
          Former KM Senior Tech
          • Oct 2009
          • 827
          Replacing the whole scanner unit is pretty easy. Just make sure to route the ribbon cables through the appropriate ferrite cores and as mentioned above, be careful of pinched wires. I've done the swap a few times and it shouldn't take much more than an hour or so to remove the old one and put in the replacement.
          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
