check paper size for tray 3 on PC-410
  • SAR
    • Jul 2009
    • 203
    I have a couple of C554e's displaying this message intermittently. On one machine, it will push the second paper stack halfway across, then stop and display the message. Sometimes it just displays the message when the tray runs out of paper. The correct paper size is displayed on the op panel and the orange gate in the center is fine. If you reset the tray, it will work fine for a while, but it always comes back with the error.
    Saw another thread on here about a part called a dumper? but would like to get confirmation before I start ordering random parts.
    Thanks for your help!
  • mo0651
    • 1054
    Re: check paper size for tray 3 on PC-410
    Check Service mode, System #2, Lct size.
    • copyrooks
      • Oct 2013
      • 209
      Try seeing if the paper is uneven when it feeds a bit out of the tray. If you notice it is, i'd go for the dumper not too bad to replace at all.
      • SAR
        • Jul 2009
        • 203
        Already checked the LCT paper size setting in system 2, it is set to the correct size.
        Does the dumper only effect the tray when feeding paper? This error occurs when the machine runs out of paper, or is shifting the tray.
        • allan
          RTFM!!
          • 5462
          Silly question. Been working on these for some time.
          What is a dumper?
          Whatever
          • copyrooks
            • Oct 2013
            • 209
            What is a dumper?
            It's #12
            • korthr5
              • Feb 2016
              • 39
              Hello
              I have the same problems 2 times.
              Frist time i have piece of paper on the plug connecting the cassette to the bottom of the paper cabinet.
              Second time the plug on the bottom on the cabinet was not on the correct position whem you close the cassete sometimes work sometimes not.
              • Norbi-HU
                • Sep 2023
                • 2
                I have stucked elevator motor (M134) and shifter motor (M133).
                I clean both of them and problem solved!
                • Ziggy
                  • Feb 2018
                  • 720
                  What is a dumper?
                  Its actually a damper . Its misnamed in the parts manual. It stops the cable pulleys from turning after you open the tray especially if its loaded with paper. If the dumper (damper) is bad the cable pulleys will continue to rotate when the tray hits bottom when loaded with paper causing the cable to jump off pulley and the the paper raises crooked and causes jams and skews
