Bizhub fs-533 motors?
  • mrfuser
    • 1627
    Does anyone have these or know if they are the same on other finishers?
    A2YUPPT400 Stapler Movement Motor
    A2YUPPW300 tray lift up motor
  • Bix
    • Apr 2018
    • 1421
    Re: Bizhub fs-533 motors?
    Hi, can I ask you why?
    I had an alleged problem with those pieces. In fact, I later discovered that a photointerrupter sensor did not operate them.
    • mrfuser
      • 1627
      Getting 1102 code. Stapler operates upon boot a couple of times then goes into code.
      • Bix
        • Apr 2018
        • 1421
        Ok, my mistake, however, I get stuck immediately at the first print.
        Then I would exclude that sensor but I would take into account the finisher board.
        • mo0651
          • 1054
          After a cross reference search, They are unique to that finisher.
          The error code is for tray up/down movement.
          • korthr5
            • Feb 2016
            • 39
            A2YUPPT400 Stapler Movement Motor - FS-533 and FS-538
            A2YUPPW300 tray lift up motor - FS-533 and FS-538
            • Synaux
              • Mar 2012
              • 1224
              Not sure how difficult this is to take off without looking at it, but I have a fs533 for parts--willing to sell motor if interested.
              • mrfuser
                • 1627
                Where located?
                • Synaux
                  • Mar 2012
                  • 1224
                  Where located?
                  Texas
                  • mrfuser
                    • 1627
                    Why is the error code for a tray lift motor when the trade does not lift?
                    • Bix
                      • Apr 2018
                      • 1421
                      Does it make a small movement or absolute zero?
                      • mrfuser
                        • 1627
                        • Bix
                          • Apr 2018
                          • 1421
                          today I had a code C-1106. I removed the side covers and I pushed the stapler at the bottom. Now the code does not seem to appear.
                          I advise you to do the same thing for the tray. If you can manually lower it completely, the problem could be solved without replacing anything.
                          • mrfuser
                            • 1627
                            Ok all, small internal finisher here, FS533. The exit tray is stationary and NOT a moving part that I can see so why the 1102 code?!?!? Not , 1106 or 1101 or any other code.
                              • 15071
                              The exit tray is definitely a moving part. It raises and lowers. That's why the 1102 code. Look closer, maybe remove some covers.
