951 power failure during firmware upgrade!
  • allan
    RTFM!!
    • 5462
    [Dead] 951 power failure during firmware upgrade!
    Hi Guys
    Got an actual problem.
    Machine not booting after a power failure during firmware upgrade.
    Going to scourer the manuals now, know there is a procedure to recover it.
    Anybody know of this or done it before?
    Whatever
  • allan
    RTFM!!
    • 5462
    Re: 951 power failure during firmware upgrade!
    So do i have this right?
    Create PRESS_1250M folder and copy folder (I) from firmware there then rename the file A4EU041_00I0_G00_5000.bin under the folder IO to recover.bin?
    But there is more than one bin file in there. How do i know the right one?
    Wow the manual is useless here!
    Whatever
    • Synthohol
      Certified Konica Expert
      • 5814
      all the files go there, the machine picks the right one IIRC.
      wait, i thought the whole I0 folder gets copied over?
      • allan
        RTFM!!
        • 5462
        It seems it is for 2 models the A4EUx seems to be the right one for the range, guess the other file is for the 1100?
        Whatever
        • allan
          RTFM!!
          • 5462
          Nope can not get this to work!?
          Whatever
          • allan
            RTFM!!
            • 5462
            Anybody really in trouble here.
            Whatever
            • tulintron
              • Jul 2014
              • 668
              Does the panel start a process?
              Have you checked if there are any icp burned on any of the boards?
              I think I should start updating from the old firmware.
              • allan
                RTFM!!
                • 5462
                The machine is stating starting please wait with orange LED flashing.
                The orange LED flashing as per manual means the OACB has wrong or no firmware written.
                Or error detected in ISW standby (memory check) after power up.
                Pretty sure no hardware is damaged.
                Or may be not so sure, only other reference is that the SSD got damaged during power failure while in ISW.
                But want to make sure i am getting the procedure right and the manual is vague about it.
                Do i create a new file called recover.bin?
                I am not the one at the machine, helping a fellow tech on our machines.
                Whatever
                • Leyahné
                  • Feb 2016
                  • 44
                  If my memory serves me right, on page 1288 of the service manual follow those instructions. Should be J-18. Load the mass production FW and then copy the FW back into the IO Folder. When loading the FW, load the Image control and the print control together with the OAC board aswell
                  Sent from my SM-N960F using Tapatalk
                  • allan
                    RTFM!!
                    • 5462
                    Where does this recover.bin come in?
                    Whatever
                    • tulintron
                      • Jul 2014
                      • 668
                      • allan
                        RTFM!!
                        • 5462
                        Well thanks for your help renaming the folder called IO to recover.bin does not make sens to me but i will try anything at this point.
                        Its linux after all folder/file is the same thing. Could be as simple as that. Will give it a wack.
                        Whatever
                        • tulintron
                          • Jul 2014
                          • 668
                          • allan
                            RTFM!!
                            • 5462
                            The guy got the machine back up still not sure what how or why.
                            Seems like you need to rename the folder IO to recover.bin
                            Thanks guys.
                            Whatever
