Horizontal white lines on Bizhub c220 + PHOTOS
  • allan
    RTFM!!
    • 5462
    #16
    Re: Horizontal white lines on Bizhub c220 + PHOTOS
    Thanks for the meter count. That gives a lot of insight.
    Next time print half-tones from service mode than will eliminate confusion.
    Then the colors will be true CMYK and will then show only the color at fault.
    So well done, change the drum out.
    Whatever
    • copyman
      Owner / Technician
      • Sep 2005
      • 4709
      #17
      Not sure what more you expect techs on a forum to do? You have been given some very good FREE advice but at a point not sure what else we can do without being at machine.
      Just a "guess" I say your drum(s) are bad. I know you swapped them around but if all drums same age more than one or all may be bad. But agree with other poster if you don't know what a transfer belt is then you are getting in way over your head. If you want to take a chance and start taking transfer belt, etc out of machine, beware your could do some serious damage! I've seen this same exact scenario play out on this forum many times. 99.9% of the time end user ends up having to call a tech anyway costing them 2-3 times what it would of cost if they just called a tech in the first place.
      If the tech is like me I don't mind showing someone that is handy how do do certain things on their own, which will save them money in the future. better to show someone in person. If you don't think it's worth $100 to find out what the problem is then you deserve to pay 2-3 times more. Let a qualified technician troubleshoot and tell you what is wrong. Then if you want buy the part and put it in yourself go for it. But at least your not guessing and buying parts that might not fix it.
      Best of luck
      • allan
        RTFM!!
        • 5462
        #18
        Originally posted by Hansoon
        Besides the information from Allan, I just had one to rebuild in the workshop, an extremely dirty machine. A very similar pattern appeared. We "cleaned" the laser windows with the build-in cleaning wand. Problem still exists. Made a "better" cleaning tool with a primitive wooden stick just wide enough to enter the gap in the frame above the slit glass. On its end I put sponge tape from the kind one uses for windows. This cleaned the slit glass much more better and the white lines disappeared.
        Hans
        On those rebuilds and in the field i found it necessary to remove the PH unit to clean
        Whatever
        • Hansoon
          • Sep 2007
          • 3385
          #19
          Well not me for the moment.
          You guys think I should apply for a patent for this high tech tool? LOL
          Hans
          BTW: You can use it also as a very good back-scratcher. Before using it in the copier.....
            • 14754
            #20
            [ATTACH=CONFIG]41856[/ATTACH][ATTACH=CONFIG]41857[/ATTACH]
            Hans
            What do you do when a piece of the black foam rolls off and sticks to the printhead?
            • tsbservice
              Field tech
              • 8019
              #21
              That Q was in my mind two hours ago. You are right but...my heart just didn't let me to ask.
              Anyway, good idea to clean laser slit more closely, KM jig/wand obviously isn't enough.
                • 23008
                #22
                Hans
                Extra points for creativity and lateral thinking! =^..^=
                • Hansoon
                  • Sep 2007
                  • 3385
                  #23
                  Than I use the "Rolled-Off-Black-Foam-Removal-Tool" ofcourse.
                  Hans
                    • 14754
                    #24
                    Hans
                    Wow, you have a tool for everything!
