FS-534 joggers
  • copyman
    Owner / Technician
    • Sep 2005
    • 4788
    FS-534 joggers
    Another weird one, when "printing only" the joggers work fine until the 10th page, it ejects the first ten pages fine then next page it will catch the paper and wrinkle the edge. ONLY when printing, doesn't do it copying.
    I swapped whole finisher main body & did finisher adjustments still does it.
    Anyone ever see this?
    • 23010
    Re: FS-534 joggers
    They're called Regulating Plates, and a search might have brought you up thus post:
    FS-534 alignment plate wearing.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4788
      Re: FS-534 joggers
      Thanks cat. I'm aware of the "regulating plate" issue. But as I posted this is strange as it only happens when printing not copying. If it was the common issue you refer to and I'm aware of wouldn't it do with both copying & printing? You can watch it work perfectly when copying, same exact operation as when printing, but with printing it will eject the first set and next page catch.
      Also I swapped a finisher which only had 31K on it. The original finisher had 80k. Logically thinking, what are the chances of both these low meter finishers causing the problem?
      • tech51
        • 846
          • 15069
          Re: FS-534 joggers
          When you installed the finisher did you upgrade the firmware at the same time. Might be worth a try.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4788
            Re: FS-534 joggers
            I was thinking same thing with the data clear. I will bring latest FW with me. Just to be clear the machine does not jam when it catches, it just wrinkles the edge of paper.
            Was also thinking about trying a different driver since only happening when printing. Now that is NOT logical thinking. What the hell would the driver have to do with it!
            • srvctec
              Former KM Senior Tech
              • Oct 2009
              • 827
              Re: FS-534 joggers
              Unless the driver somehow thinks the paper is narrower than it is and thus making the finisher crunch in the alignment guides a bit too far, causing the crease? I seriously doubt that's possible, though.
              Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                • 23010
                Re: FS-534 joggers
                ... Was also thinking about trying a different driver since only happening when printing. Now that is NOT logical thinking. What the hell would the driver have to do with it!
                When none of the logical things work, it must necessarily be one of the illogical things. The reasoning usually become clearer when you've narrowed your field of view.
                Keep us informed. =^..^=
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4788
                  Re: FS-534 joggers
                  Will report back what I find.
