Cannot Print Test Page from PS Driver
  • allan
    RTFM!!
    • 5462
    #16
    Re: Cannot Print Test Page from PS Driver
    Also try LPR as port type.
    Whatever
    • Synthohol
      Certified Konica Expert
      • 5849
      #17
      not for nothing, in pagescope, can you choose the "personality" of the printer?
      usually PCL or PS and AUTO are the choices. maybe yours id set to PCL instead of auto and obliterates a PS job coming in.
      also in user/printer settings, is PS an option?
      can you also print the PS font test pages?
      • NeoMatrix
        Senior Tech.
        • 3513
        #18
        Try deleting all the files in the PC spooler directory on each PC. There could be a PC with a corrupted file jamming/hogging print queue.
        Below is a batch file that deletes all files in the print queue on each PC.
        hhttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software.html#post561092
        http://www.copytechnet.com/forums/co...tml#post561092
        HTH
        • ajayprajapati
          #19
          Originally posted by Bix
          Does the print remain queued in the PC or is it sent to the printer and then not printed?
          Check to see if something appears in the job list of the printer.
          Hello Bix,
          I had the similar issue in past. You can try print test page online to figure out the solution.
