Cannot Print Test Page from PS Driver
  • patk
    • Jun 2008
    • 56
    Hi- Can anyone suggest anything here
    Client uses Konica Minolta PS Driver to print PDFs to Bizhub C308 but jobs constantly error out and do not leave print queue.
    I have deleted the PS driver and print queue entirely and reinstalled using PS diver 9.1.16.0. and cannot get the machine to print anything even a test page.
    The Konica Minolta PCL driver prints perfectly using the same port.
    They are using Windows !0 Pro x64 PCs
    Any ideas?
    Cheers
    Pat
  • tsbservice
    Field tech
    • 8020
    Re: Cannot Print Test Page from PS Driver
    A couple:
    - Machine has old FW, try to update FW.
    - Did you go with automatic driver installation using an installer or manual installation using Add Printer? Sometimes automatic installer sucks.
    • patk
      • Jun 2008
      • 56
      Thanks for that
      F/W is latest version GC1-W4
      I didn't use Auto-installer, did manual install via Add Printer
      Cheers
      Pat
      • D Colour
        • Oct 2008
        • 216
        We have had a few problems were print jobs would just go into the queue, sit there and never print. I don't think it is the same issue as you are having as you say the PCL driver prints out fine.
        In our case it was a print spool problem. If you run this tool it will clear it. But i have my doubts this is your solution. Its worth a try.
        (Solved) How to Fix Print Spooler not Running - Free Fixit Download
        Everything that has a beginning, has an end.....
        • patk
          • Jun 2008
          • 56
          Thanks for that
          I had already checked out the print spooler. Stops and restarts just fine, no error messages and PCL driver is operating normally.
          Cheers
          Pat
          • D Colour
            • Oct 2008
            • 216
            Is the issue the same on all the PC's? Or just 1
            "Use Printer Offline" wouldn't be ticked?
            • Bix
              • Apr 2018
              • 1421
              This could be stupid but ... did you restart your computer?
              • patk
                • Jun 2008
                • 56
                Hi
                Printer Not offline
                PC was restarted
                Also connected laptop to printer via crossover cable and printed via PS driver normally so not a problem with the C308
                Cheers
                Pat.
                  • 14815
                  Originally posted by patk
                  Hi
                  Printer Not offline
                  PC was restarted
                  Cheers
                  Pat.
                  Is the C308 using account track or user authentication?
                  • patk
                    • Jun 2008
                    • 56
                    Thanks for reply
                    No - Account Track and User authentication both disabled. And Printing Preferences set to Print, not send to User Box etc
                    Cheers
                    Pat
                    • Bix
                      • Apr 2018
                      • 1421
                      Does the print remain queued in the PC or is it sent to the printer and then not printed?
                      Check to see if something appears in the job list of the printer.
                      • patk
                        • Jun 2008
                        • 56
                        Thanks for reply
                        Job remains queued on PC, does not reach printer. Get failed to print error message
                        Cheers
                        Pat
                        • Bix
                          • Apr 2018
                          • 1421
                          The computer is like it does not detect PostScript support in the printer.
                          You try to go to Printers> Right click> Printer Properties> Configure> Get Settings ... and enter the IP address Manually.
                          In the "Ports" section, make sure there is a flag on "Enable bidirectional support" and disable "Enable print spool" (make sure this flag is not present in all drivers).
                          In advanced, set "Always available" and "Use the spooler to speed up the printing process". Disable "Do not print documents with mismatched settings".
                          Alternatively, try reinstalling the PostScript driver with Konica Minolta installer.
                          Try to see if the previous firmware occurs. HEX Assignment:
                          No. 25
                          HEX A0 -> Function Version 4.1
                          • rrrohan
                            • Sep 2011
                            • 1977
                            Thanks for that
                            Cheers
                            Pat
                            why do they want PostScript so bad, if PCL works then just use that?
                            Also i would re download the driver maybe something is corrupt
                              • 23009
                              If it's just the one PC acting out, then I'd connect my laptop to that network cable and do a ping back to the server, or printer, or any other node on the network. You might find that you've got a slow network connection or dupe on that PC. =^..^=
