konica minolta 364e
  • frenk22
    • Mar 2019
    • 2
    konica minolta 364e
    buongiorno ho una bh 364e si riavvia in continuazione
    hanno detto sia la ssd mi aiutate a trovare il firmware e una ssd nuova
    grazie
  • Toxic
    • 696
    Re: konica minolta 364e
    You could do at least to use google translate.
    Btw i dont think you will get solution here,that is problem for KM tech for sure.
    • copier tech
      • 8130
      grazie
      This is a known issue, you need to replace the SSD board.
      You could try firmware first but each instance of this issue replacing the ssd resolved the issue.
        • 22990
        Per Google Translate:
        good morning I have a bh 364e and restarts continuously
        they said both the ssd help me find the firmware and a new ssd
        thank you
        You'll have to call the hotline to get the new SSD under warranty.
        Dovrai chiamare la hotline per ottenere il nuovo SSD in garanzia. =^..^=
        • frenk22
          • Mar 2019
          • 2
            • 22990
            You'll need to open up a relationship with a local Konica Minolta dealer to elicit their help, for your convenience in Italy.
            Avrai bisogno di aprire una relazione con un rivenditore locale Konica Minolta per ottenere il loro aiuto, per la tua convenienza in Italia.
              you need to start using Google Translate.. Post in English PLEASE!
                • 14467
                Google translate works both ways.
