bizhub C224 paper select issue.
  • ck1
    • 485
    i have one c224 got this issue . when you put at glass or feeder , it show this massage . any setting ?
  • tsbservice
    Field tech
    • 8020
    Re: bizhub C224 paper select issue.
    It's very hard to see from picture you post, but it looks like machine asks for A3 paper size. Few Questions from here.
    -do you have A3 paper set in any drawer?
    -what's the original size?
    -WHAT's wrong with using Google translate to describe roughly problem, and don't let us guessing?!?
    • ck1
      • 485
      Yes original is A3 size and my tray have A3 paper , but it no auto switch to the tray and show massages . You must manually select the tray. Even use feeder also same
      the massage is paper of matching size is not available
      select the paper matching paper : A3
      • rrrohan
        • Sep 2011
        • 1977
        Is the A3 tray highlighted in auto tray selection in user mode?
        • Synthohol
          Certified Konica Expert
          • 5849
          is the A3 tray set to anything but plain?
          that would cause it too.
          • allan
            RTFM!!
            • 5462
            The original detection is screwy. Make sure the DF lenght sensor is not trapped.
            Make sure the platen glass and optics including the platen length sensors are clean.
            Or swop the 2 sensors around. Toggle between tabel1 and tabel2 in service mode under original detection.
            Then toggle back. Cant tel you why but fixed that problem before.
            There was a while that problem plagued me and after tinkering mysteriously resolved itself
            Also there is sensor check...
            Whatever
            • jwai
              • May 2018
              • 509
              Solve it by cleaning optical section. ( original glass, mirrors, lamp, lens, size detection sensors )
              • ck1
                • 485
                yes A3 siza at 2nd tray and setting at auto select
                • ck1
                  • 485
                  thanks i will try it
                  • rrrohan
                    • Sep 2011
                    • 1977
                    To be clear I mean
                    Utility - user settings - system settings - paper tray settings - auto tray selection settings
                    And tray with A3 is highlighted yellow?
                    Alsoake sure your A3 tray is set to Plain paper
                    • ck1
                      • 485
                      To be clear I mean
                      oh ... ok thanks i try
                      • greglogston
                        • Jul 2018
                        • 34
                        Originally posted by alamsandhu
                        check the Bypass paper senor is actuated, remove the paper or the particle blocking the bypass paper feed! might be Paper feed Empty sensor is blocked.
                        His problem is the machine detects paper on the glass when it's not there i'm assuming. I had this issue today and am looking for a fix. When I close doc feed it thinks there is an original on the glass. If I lift it up a couple inches and back down again it fixes it. Also, weird, but if I power cycle it doesn't do it.
                          • 14813
                          Cleaning the underside of the glass almost always fixes that problem
                          • greglogston
                            • Jul 2018
                            • 34
                            • rrrohan
                              • Sep 2011
                              • 1977
                              im confused. is the OP saying that
                              detects original size as A3 on glass when it shouldnt
                              or
                              when you try to print A3 it doesnt take it from A3 tray and instead ask you to load paper in bypass/manual feed tray?
                              i thought it was that A3 tray issue
