Vertical Bands C1070
  • ttopman
    • Sep 2018
    • 9
    Hello guys,
    I need help with this I started getting two vertical lines a cross all pages on Yellow and Magenta lines. Drums are at 21%. Shortly after this, error C4631 began to pop up.
    Any ideas how to resolve this?
    Re: Vertical Bands C1070
    Originally posted by ttopman
    [ATTACH=CONFIG]42021[/ATTACH]
    Hello guys,
    looks like a M dev unit
    • Toxic
      • 697
      What is distance between this white void areas?
      Approx 188mm pitch: Damage on the drum surface
      Approx 44mm pitch: Developer conveyance failure of developing sleeve
        • 23003
        Yup, I'm thinking drum too. =^..^=
          I thought I saw LEF Feed. Am I wrong?
            • 23003
            I viewed this print as Ledger (11 x 17) or Full Bleed (12 x 18), SEF. Super B+ (13 x 19) would have larger voids. These are the typical paper sizes used on the presses. =^..^=
              well I can't remember the last time I didn't agree/digress to your views BC.. so put another one in the "W" column
              • Synthohol
                Certified Konica Expert
                • 5814
                near the bottom of the voids there seems to be a mark that may be foreign material stuck somewhere that pushes the mag roller back momentarily?
                • ttopman
                  • Sep 2018
                  • 9
                  Measured the lines, it's approx 88mm gap.
                  I have this on Yellow too. Dev mag roller shows no sign of failure.
                  Find this very annoying
                  • ttopman
                    • Sep 2018
                    • 9
                    We've had the drums checked. There was some artifact there, had it removed at the expense of the drums. The problem though is that I have this on Yellow as well, the yellow drums are clean and good.
                      • 23003
                      I've had my share of invisible drum flaws. Swap the drum to another color. If the flaw follows, replace it. =^..^=
                      • tsbservice
                        Field tech
                        • 8003
                        So sample is A4 size, lines are in parallel with feed direction, right?
                        • ttopman
                          • Sep 2018
                          • 9
                          Print is 12x18. Yes in feed direction
                          • tsbservice
                            Field tech
                            • 8003
                            Sample Full Bleed 12x18 and distance between white bands is ONLY 88 mm. And in feed direction?
                            Somehow hard to believe that from what we can see. Are you sure distance isn't 188mm?
                            Go swap drums and report back.
                            • ttopman
                              • Sep 2018
                              • 9
                              Changed the drums. The gaps are gone. It was invisible drum damage.
                              Thanks everyone.
