Konica BH 222 C2557 code
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
  • ck1
    • 485
    Re: Konica BH 222 C2557 code
    ATDC too high . try step by step adjust drop to 160 . need take time to adjust and print more copies
    • Bliki BZ
      • Oct 2018
      • 10
      Toner is not getting into developer I have seen this issue several times years ago working on this series you need to remove toner hopper unit from belly of copier couple of hidden screws accessed from back of machine vacuum out sub hopper clean or replace sensor or magnet switch if still available. Its a big job to get to it . May need to replace the developer powder again to recover from code be sure toner bottle is full it will take time to refill hopper.
      • blazebusiness
        • 1257
        Sounds like the right advice............I suspected this was a toner supply issue. Thanks to all for the replies.
        • mo0651
          • 1054
          Toner bottle solenoid not firing or sticking.
          • Woxner
            • Jul 2011
            • 851
            did you reset the drum and dev counts before you ran f8? also at this age the foam on the toner solinoids are gummy.never seen a sub hopper problem in all my years. but can happen
            • srvctec
              Former KM Senior Tech
              • Oct 2009
              • 827
              My guess is that it's the stupid sponge KM put on the solenoids in the toner hopper add assy. The sponge on each of the 2 solenoids will fail and all that's left is the sticky adhesive, causing the machine to add toner all the time, which is why increasing the ATDC value temporarily fixes it. Remove the toner hopper/bottle drive assy and clean off the sponges of each solenoid. Pro tip- put some mylar, 2 or 3 layers thick on where the sponges were, otherwise the solenoid flapper will magnetically stick to the solenoid frame. Ask me how I know. Been fixing 350 series and later like this for many years.
              Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
              • Jakobi
                • Mar 2019
                • 16
                I've got a BH 222 with same error few days ago. made same part changes: developer+image unit (all new); F8 ok, reset counters ok. After a few days 2557 error. Whith srvctec advice i've start the work. Guess what: solenoid was glued. And stays glued when i take out the subhopper assy and put it on table. I've made a photo whith that. After remade the solenoids, the machine works just fine. By the way, i've used a piece of heat shrink tube instead of pieces of mylar.
                • copier tech
                  • 8176
                  [ATTACH=CONFIG]45201[/ATTACH][ATTACH=CONFIG]45200[/ATTACH][ATTACH=CONFIG]45199[/ATTACH]
                  Id expect this in a machine of this age but not on later models.
