Konica minolta Bizhub C451 Transfer belt gear Pronlem
  • matsan_offset@yahoo.com
    • Sep 2016
    • 43
    [Jamming] Konica minolta Bizhub C451 Transfer belt gear Pronlem
    Hi guys,
    My machine is Konica minolta Bizhub C451 Constantly breaking the Transfer belt gear.
    Why do you think? Thank you in advance for your help.
    Re: Konica minolta Bizhub C451 Transfer belt gear Pronlem
    Originally posted by matsan_offset@yahoo.com
    Hi guys,
    something is wrong in the copier.
    • copier tech
      • 8144
      Hi guys,
      Can you be more specific, when you say "Transfer belt gear" which one are you referring to?
        WAIT. WHAT??? You mean there are more that ONE gear? (Sarcasm)
        • copier tech
          • 8144
          "Sent from my SM-G960U using Tapatalk"
          Nice phone (sarcasm)
            I like my Samsung S9..
            • copyman
              Owner / Technician
              • Sep 2005
              • 4702
              Said i wasn't going to interview people to try and help them! But I will give them benefit of the doubt of language barrier. Wouldn't a picture of gear been great!
              Copier 101, this should be one of the easiest issues to troubleshoot. Not sure about the repair.
              If transfer belt gear keeps breaking then wouldn't it make sense that toner is backed up and not allowed to be augared into waste box. You may have to vacuum out entire waste pipe but would start with the chutes that go into waste box. Maybe replace waste box.
              You can check everything on the trans belt unit, remove cleaning unit (2 screws) and turn gears by hand to watch auger and other operations. Also turn trans belt by hand with big white gear (turn belt in proper direction if cleaning unit attached)
              • copyman
                Owner / Technician
                • Sep 2005
                • 4702
                Said i wasn't going to interview people to try and help them! But I will give them benefit of the doubt of language barrier. Wouldn't a picture of gear been great but I'll have to guess at which gear! Copier 101, this should be one of the easiest issues to troubleshoot. Not sure about the repair. If transfer belt gear keeps breaking then wouldn't it make sense that toner is backed up and not allowed to be augared into waste box. You may have to vacuum out entire waste pipe but would start with the chutes that go into waste box. Maybe replace waste box. You can check everything on the trans belt unit, remove cleaning unit (2 screws) and turn gears by hand to watch auger and other operations. Also turn trans belt by hand with big white gear (turn belt in proper direction if cleaning unit attached)
                  • Sep 2016
                  • 43
                  This is the gear I was talking about. Also I meant to say grinding, not breaking. The gear is grinding. The machine makes loud noises. When I first started the machine, an error message occured that said to open and close the front door (where waste box is). When I did so, the grinding happened and loud noises occured. I keep changing the gear but the problem keeps occuring. What could be the main problem?20190318_111235.jpg
                    • Sep 2016
                    • 43
                      • Sep 2016
                      • 43
                      • Flash
                        • 378
                        There is an updated transfer belt drive assembly for this problem. Go to PrecisionRoller.com: Online Shopping for Toner Cartridges & more and scroll through the parts for the C451. They sell the parts you need as a kit.
