Bizhub C353 backgrounding
  • aAandy
    • Apr 2012
    • 370
    [CQ] Bizhub C353 backgrounding
    Hello Gentlemen and Gentlemen (if there are any ladies present, i apologize)
    was called to this machine today with multicolored background (all colors), no problems printing mono, no error codes, no P codes
    removed laser units & blank lamps & cleaned, replaced M imaging unit with a brand new one, no change to the M part of the equation - ITB looks near new and ITB cleaning unit is working well, also cleaned ITB sensors & performed stabilization (clear data) and all gradations
    changing 'background voltage' in service mode reduced but did not eliminate the problem - the attachment has the background voltage at max(or is that min) so you can actually see the problem
    anyone seen this before got any eye deers? any help would be very much appreciated
    thanks in advance
    Andy
  • copier tech
    • 8133
    Re: Bizhub C353 backgrounding
    thanks in advance
    Andy
    What is the life of the transfer belt on?
    • aAandy
      • Apr 2012
      • 370
      to be honest i don't recall checking, when i see an ITB in such good condition i guess i don't look - besides, an ITB cannot transfer what isn't there - right?
      where are you going with this train of thought? i should have done a stop test to see if the background was on the drums,,,, but i was pressed for time
      two things are bothering me about the attachment,, the lines through the background, and the size/length of them - should be ringing bells,, but the bells are silent
      • allan
        RTFM!!
        • 5462
        Had it many times were its otherwise the HV cable or the laser ribbon cables that cause all kinds of weird stuff on these models.
        Or one of the IU's that arcs. Good old trouble shooting.
        Whatever
        • copier tech
          • 8133
          You dont recall checking the transfer life? This is basic trouble shooting these counters are there to help you. A visual check is not always enough.
            • 14597
            Is that cross hatch pattern on the original, or was it added when you scanned the document?
            • tsbservice
              Field tech
              • 7999
              Try to block(temporarily) one of PH windows by tape. If background of that color disappears your PH unit may be faulty.
              • aAandy
                • Apr 2012
                • 370
                it is on the original
