konica minolta bizhub 754 ghost image
  • copyman
    Owner / Technician
    • Sep 2005
    • 4542
    #16
    Re: konica minolta bizhub 754 ghost image
    I didn't look at the sample until after. Even after seeing sample I can't trust it wasn't run through ADF with other originals and ghosting from a different original.
    As i have posted here before, This is what I mean about never providing enough info to make it easy to help. How hard is it to run the internal test pages, in this case the font list since it don't happen on first page in 11x8.5 direction (portrait).
    Regardless of what is causing the ghosting it should be one of the easiest issues to solve.
    • allan
      RTFM!!
      • 5459
      #17
      My guess is the developer is over run and the fuser too.
      Blades on these would probably smear and make lines instead of a clear image.
      Whatever
      • amitlama_78
        • Oct 2009
        • 62
        #18
        The file was printed on LEF (long edge feed) = A4
        • qbert69
          • Mar 2013
          • 1152
          #19
          What page was printed prior to the page with the defect???[emoji848]
          Sent from my SM-N950U1 using Tapatalk
          REACH FOR THE STARS!!!
          Konica Minolta Planetariums!
          • allan
            RTFM!!
            • 5459
            #20
            Reduce the density and up the fuser temp by +5 to check what happens.
            Whatever
            • qbert69
              • Mar 2013
              • 1152
              #21
              Additionally, is it using OEM toner?...if not, sometimes non OEM toner requires boosted fuser temperature to get it to bond with the paper properly!!![emoji6]
