konica minolta bizhub 754 ghost image
  • amitlama_78
    • Oct 2009
    • 62
    [Misc] konica minolta bizhub 754 ghost image
    Hi guys
    I have this machine km754 which prints ghost image.
    First copy is ok when i do multiple copies the first copy comes fine but from the second copy on the upper side i get the fade ghost image of the first copy.
    I could not figure out the problem.
    Would appreciate if someone could help me out.
    Im also missing the .mov file for the said machine if anyone would like to share please do share on my email id ie Amitlama_78@yahoo.com
    regards
    Amit
    Re: konica minolta bizhub 754 ghost image
    Originally posted by amitlama_78
    Hi guys
    First copy is ok when i do multiple copies the first copy comes fine but from the second copy on the upper side i get the fade ghost image of the first copy. I could not figure out the problem.
    regards Amit
    Well.... just off the top of my head having NO REAL information provided...
    replace drum and or fuser
    or if you'd care to provide:
    Total pages on machine...
    Pages left on supplies..drums/fuser/belt/transfer
    what has been done
    PMs done on time
    Cert'd tech doing the work
    do you have SM
    • qbert69
      • Mar 2013
      • 1152
      Hi guys
      regards
      Amit
      ...but....BUT...LLAMA WANTS FILEZ!!![emoji23][emoji23][emoji23]
      Llama Spits GIF - Llama Spits Kid - Discover & Share GIFs
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • tsbservice
        Field tech
        • 8026
        Just measure the distance between repeated/ghost images and post it.
        Most likely your fuser unit needs rebuild/change.
        • amitlama_78
          • Oct 2009
          • 62
          i HAVE JUST ATTACHED THE FILE PLEASE TO HAVE LOOK
          • Synthohol
            Certified Konica Expert
            • 5851
            does not line up and the font of the shadow appears smaller.
            did you print that lef or sef?
            • amitlama_78
              • Oct 2009
              • 62
              No the font is same....
              Have printed as landscape (left)
              • Synthohol
                • 5851
                landscape left is not an good description.
                when the paper exits the machine does it come out short edge first or long edge first.
                portrait and landscape describe the orientation of the image.
                the image shown is portrait.
                • tsbservice
                  Field tech
                  • 8026
                  Interesting image, looks like ghost image is reduced at about 80-90%.
                  May be either drum discharging(memory) or fuser related, but reduced size and shifted position are puzzling.
                  • amitlama_78
                    • Oct 2009
                    • 62
                    Images comes on long edge first
                    • qbert69
                      • Mar 2013
                      • 1152
                      LOOK AT THE "g" IN THE WORD "Augmented"!!! NOT EVEN THE SAME TYPEFACE/FONT!!![emoji15][emoji33][emoji2962]
                        • 23009
                        My thoughts exactly.
                        First: you probably have a bizhub 754e, not a 754.
                        Second: The shadow image is shifted both in the main scan and subscan directions, which in itself is unlikely. Usually it's ghosting in the sub scan, very rarely in the main scan direction.
                        Third: I'm still unclear: What direction was this printed? SEF (short edge feed) = LTR-R or A4R, or LEF (long edge feed) = LTR or A4. Portrait or landscape descriptions are meaningless as to paper orientation.
                        Fourth: Yes the ghost image is a smaller font than the image above it. Could the ghost image be coming from a similarly imaged page before it?
                        If you'd like a better analysis please attach the full sized PDF scan and answer some questions. =^..^=
                        • Synthohol
                          • 5851
                          ive seen this kind of thing before, there is likely a layer of the (previous) header under the current header layer and when the pdf was flattened it bled through.
                          try another program to print from, i use foxit reader as adobe will have these kinds of issues.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4726
                            No need to over analyze, very simple. It's either fuser, drum or transfer belt. This is perhaps one of the easiest issues to troubleshoot, stopping paper mid-cycle, etc. If you are a tech look at the 3 things I mention if not call a tech!
                            • Synthohol
                              • 5851
                              copyman, the font is different in the shadow. if it was a drum belt or fuser the shadow would be exactly the same and lined up with the image it pulled it from off a roller.
